Building a CPU and I want the propeller to be my GPU — Parallax Forums
super_tntsuper_tnt Posts: 9
edited 2013-10-17 12:34 in Propeller 1
I'm starting to design and build a CPU (no I'm not crazy) and I want the propeller to be my GPU. The setup I want to have is the propeller connected to one port of a dual port sram so it can read the video ram and put it out as composite video. The other port will be connected to my CPU so it can read and write video ram. I want 8 bit video in the form of: 332 (RGB) and to let the CPU know it is ok to write to video ram to avoid artifacts maybe with Vsync. is this possible, if so what resolution can I expect?
  • Mark_TMark_T Posts: 1,981
    edited 2013-10-16 08:20
    Which SRAM are you contemplating?
    edited 2013-10-16 09:47
    A wide range of resolutions are possible, but which you use depends more on the size and speed of the ram you plan on using.
    What is the minimum resolution you would find acceptable, and what resolution do you really want?
  • super_tntsuper_tnt Posts: 9
    edited 2013-10-16 10:16
    Ideally I'd like 640x480 but that would require a huge sram so the lowest I would go with would be 320x240.
    I've not had a good luck at the SRAM but this one seems ok: CY7C130-55PC A little slow but it's in DIP package and that would make it very easy for me, otherwise I'd have to get some place to solder it for me. Obviously this is a little small so I may have to add a bunch of them and select from them when reading and writing.
    edited 2013-10-16 10:50
    Interesting. What kind of CPU do you have in mind? And how will you implement it? FPGA, TTL, transistor, relay.. other?
    Welcome to the forum by the way.
    edited 2013-10-16 12:08
    TTL, using a lot of 7400 ICs. A lot of people will tell me I should do it with an FPGA but there is something beautiful about a bunch of chips sitting on a board with wires running from each other like a busy street, this is compared to a single chip on a board. I don't want to use relay because I do want it to be some what fast.
    edited 2013-10-16 12:38
    I know where you are coming from ...
    I didn't have any 74LS32s or 74HCT00 so I reached for a CPLD (9572). The CP/M project (Grant Searle) fired up ok ;-) (in its M$ basic mode) but only 1 day later the CPLD is sat there taking 250mA on its own :-(
    and there are no pins to probe about on (where is that Dremel?)
    I now have the previously mentioned OR gate assemblies so more ironing to follow.
    Alan
    edited 2013-10-16 13:11
    Exellent. We like lot's of TTL around here.
    edited 2013-10-16 13:17
    I think single-port SRAM would be better - larger RAM available, you just have to have multiple latches on the address bus
    for the display counters and the GPU access, but you need address counters anyway which can have #OE inputs
    A trickier proposition is SDRAMs, although they greatly simplify driving a display with burst-mode reads, and they don't
    have to be clocked at anything like 100MHz, but you do have to refresh them fast enough. The complexity is in sequencing
    the opcodes to the SDRAM but it will drive a whole scanline by itself unattended. See my recent thread in Projects for more.
    edited 2013-10-16 13:22
    I'm going to be drowning in TTL chips by the time this is finished and sick of soldering. By the way I should have the ALU card done by the end of next week.
    As to ram options, I thought dual port would be very easy although if single port isn't too difficult then I'll look into that. I'll look into SDRAM as well, is the a space difference as well (more or less space)?
    edited 2013-10-16 13:28
    Do you have anything of your CPU design online yet?
    8 bit? 16bit? maybe a hybrid?
    Regular Von Neumann or something else?
    Just curious.
  • jazzedjazzed Posts: 11,803
    edited 2013-10-16 13:31
    You're in good company around here :)
    Lots of folks have that "make a CPU" fantasy. I've had it on and off since the 80's, but a verilog simulation is about as close as I've been.
    Why don't you start simple and just use the Propeller for the video memory and signal generation? Then make a more advanced version later.
    edited 2013-10-16 13:42
    Yeah, I too have that fantasy...
    Haven't gotten further than getting hold of breadboards(there was this thread about $1 breadboards a while ago), 'The TTL Cookbook' and a really, really big logic analyzer. (But that I also wanted for other work, too.)
    Of curse, as I'm mad as a hatter, my design will probably be a 1'' thick layer of cabling stuck into a couple of dozen solderless breadboards and you'd have to strain to see the chips.
    I had the idea about using the propeller for memory and signal generation but I didn't believe it had enough ram, what sort of resolutions can it do with its internal ram?
    How long ago was that $1 breadboard thread, sure would be helpful.
    also the closest I got to a CPU was a single 74181 I bought a while a go.
    edited 2013-10-16 13:53
    Graphics resolution is limited (512x384 bitmaps more or less), but text resolutions are pretty good (up to 128x64 characters?).
    There have been some fairly amazing graphic Propeller demos.
    edited 2013-10-16 14:17
    is bitmap having an array of colors and referencing them in vram? if so can't I use the byte for referencing to just store an 8 bit color of the format: 332 RGB?
    edited 2013-10-16 14:22
    I don't know all the details. It's not like using a color per-pixel LCD though.
    Maybe potatohead or one of the other graphics folks can answer it better than me.
    edited 2013-10-16 18:43
    super_tnt wrote: »
    First I would urge you to take a careful look at Mark_T's thread at http://forums.parallax.com/showthread.php/150407-Video-graphics-controller-using-Propeller-to-control-SDRAM. He has done some ingenious work to generate video with a propeller and sdram.
    If you decide to do something with SRAM asynchronous ram is the easiest to work with.
    A 640 x 480 x 8 bit display would require 307200 bytes of memory for the display so the choices are either one 512KB (4Mbit), two 256KB or three 128KB chips.
    If you were to drop the resolution to 512 x 384 the memory requirement would drop to 196608 bytes so a 256KB (2Mbit) chip would be all you need.
    You would need to generate address bits (18 or 19) to scan the video ram and this could be done with external counters or possibly by using the propeller video generator, PASM code/counters, and propeller pins.
    edited 2013-10-16 18:52
    super_tnt wrote: »
    The prop hub ram is only 32KBytes so it can not do 512 x 384 x 8 bit color. That would require 196.608KBytes. It breaks the screen up into blocks (16 x 16 pixels IIRC) and allows you to display blocks of pixels on the screen. It is similar to a text display where you display one of several characters at a specific location on the screen. It displays one of several graphic blocks at each screen location.
    edited 2013-10-16 19:03
    super_tnt wrote: »
    A bit mapped display has one memory location for each pixel on the screen. The memory location could be any number of bits from 1 bit (on off) to as many as you want. Typically it would be 8, 16, 24, or 32 bits per pixel for 256, 65,536, 16,777,216 or 4,294,967,296 colors respectively, although 8 bits of the 32 bit pixel is not usually used for color.
    edited 2013-10-16 19:20
    super_tnt wrote: »
    If you want to use TTL (or the equivalent CMOS chips) take a look at the 74181 and 74172. They were the chips of choice for the ALU and registers of many early minicomputers. Even if you decide to take another route the 74181 data sheet will provide good information.
    BTW, I would suggest using a second propeller and a few latches as the CPU to start with. You could have a 24 bit address and 16 bit data bus to address 16MB of ram, and emulate just about any 16 bit minicomputer ever made. Once you know what you want you can convert to TTL/CMOS/FPGA, or whatever.
    edited 2013-10-17 11:37
    The $1 breadboard thread...
    http://forums.parallax.com/showthread.php/148473-Dollar-Solderless-Breadboards
    It's the small 140 connector breadboards that came at that price, though. But the thread is full of other great buys.
  • ericballericball Posts: 774
    super_tnt wrote: »
    ... the propeller connected to one port of a dual port sram so it can read the video ram and put it out as composite video. The other port will be connected to my CPU so it can read and write video ram.
    First challenge is bandwidth. For composite NTSC TV video the Propeller will need to fetch from the RAM a line of pixel data every 63.5555usec. (The assumption is only the current line is stored in HUB RAM.) For 640 pixels per line and 8 bits per pixel, that works out to a bit over 10 million bytes per second. However, since the HUB RAM can only be written every 16 cycles that means the max WRBYTE speed is 5 million bytes per second (with an 80MHz clock). So your SRAM to HUB RAM code will need to pull 4 bytes from the SRAM and use WRLONG. Simply getting the pixels into the Propeller is going to be a challenge.
    super_tnt wrote: »
    The Propeller's video generator outputs YC (luma + chroma phase) for composite TV, it uses 222 RGB for VGA. While you could try to have an RGB to YC look-up table, I'm not certain there would be enough cycles even if you dedicated a COG to the job. (PASM doesn't have an indexed addressing mode without self-modifying code or slow HUB access.) It would be better to start with having the data in the SRAM in Propeller YC color codes.
