Connecting two boards together — Parallax Forums
JoAnn WildsJoAnn Wilds Posts: 1
edited 2013-10-15 18:44 in BASIC Stamp
Can you combine two boards to run off of one program?
    edited 2013-10-15 14:46
    I guess you can't.
    Each Board need a own program, but they can communicate with each other thru for example serial coms.
    Enjoy!
    edited 2013-10-15 15:12
    Correct. You cannot download a single program into two BASIC Stamp Modules at the same time. Each must have its program downloaded independently.
    The important question is why would you want to do that? Do you need more I/O pins? ... There are other ways to get those. Do you need more space for a bigger program? ... There are other Stamp models with multiple "slots" each of which stores a program up to 2K and these programs can transfer from one to another ... sort of like overlays ... there's no CALL / RETURN, just a JUMP from one slot to another. Do you need two boards so you can do two things at a time? ... Think about using a Propeller instead which can do 8 things at a time.
