I am looking for a fiber that illuminates ?
Reach
Hello guys,
I am looking for small fibers that illuminates horizontally across the fibers vs. at the ends. I prefer it to be light by an LED. I think they make larger diameter fiber optic toys that glow but I need something small (mm's). Any ideas?
IIRC, I think I had better success with illuminating the light pipe with a LED when I ground the dome off the LED and just had a flat top on the LED.
Here is the light pipe with a laser - haven't really tried it with a LED
If you're not talking about large lengths and you don't need to bend the stuff (much), I'm guessing you could get some very clear acrylic or other plastic material and lightly roughen the outer jacket of it with fine sand paper so, instead of the light bouncing around via internal reflections, some of the light leaks through the roughened areas. I've never tried it myself, but I don't see why it wouldn't work. To get the light into the fiber, you would polish its ends.
If not acrylic rod, probably cheap acrylic optical fiber would work for this if you sand off the cladding, I suppose.
http://www.sportsmanswarehouse.com/sportsmans/Lone-Peak-Replacement-Sight-Fibers/productDetail/Sights-and-Pins/prod9999011715/cat100509
http://www.sportsmanswarehouse.com/sportsmans/TruGlo-Optic-FIB-3PK/productDetail/Sights-and-Pins/prod73297/cat100509
Gordon, I've seen lots of examples of EL wire, but I don't think I've seen side-emitting fiber optics. Have you used the side-emitting stuff yourself? Did you like it?
I've used the light pipe with the white center I linked to earlier and thought it did what it claimed to do reasonably well.
I'm a fan of most things glowy, and I'm interested to hear what you all think of the various options provided so far.
Here's one outfit that sells the stranded:
http://www.fiberopticproducts.com/Sideglow.htm
Multiple strands makes it glow brighter.
You can sometimes find these locally if there's an auto customizer nearby. They use these quite a bit on the limos they pimp out.
