ADCM 2700 or ADCM 1700 CMOS Camera
Does anyone have the software to communicate with the Agilent ADCM 2700 or ADCM 1200 Landscape VGA camera? I attached the ADCM 1700 datasheet for this camera (adcm_1700_agi.pdf). The ADCM 2700 camera should have the same wiring interface and communication protocols. The output data can be transmitted using a serial or parallel port.
If you have the software to communicate with either of these cameras in any programming language please post it to this forum post thread.
pdf
304K
As far as I can see there is no object for the camera in the OBEX though there may be a suitable object (spi or similar) that could be modified.
Reading the PDF that you supplied gives some clue to the cameras operation. The PDF does suggest that you should download the technical manual (pdf) but I have not been able to locate a copy.
