error: no propeller chip on port 'COM12'
I was using a proto board through a USB to232 and the discrete circuit and it worked fine with FirstIDE and the Prop tool until I got a Propeller project board USB which worked for a little bit until it started giving me the "error: no propeller chip on port 'COM12'" I reinstalled the latest USB drivers but that didn't help and also reinstalled simple IDE but still can't find it... Help! :]
Some boards can be finicky about connection to the Prop Tool. I find, when I'm having trouble, if I press the reset button on the board half a second before pressing F10 or F11, the program is more likely to load.
You also want to make sure there isn't a serial terminal using the com port.
Start-> Control Panel-> System-> Hardware -> Device Manager
Look under Ports (COM & LPT) to see if there might be a conflict.
Also try looking at the ports with and without the USB device plugged in to see if something else is using that port.
If you right click the USB Serial Port (COMx) ... and click on Properties under "Port Settings->Advanced" you can try to manually re-assign the COM Port Number
... or from Properties under Driver you can try to Uninstall the driver.... it should re-install if you unplug, and then re-plug the USB connection.
Note: In the "Advanced settings" to manually change the COM port, it may erroneously be reporting that the COM port is "in use". if you have ever plugged in a USB-COM device, this flag gets marked, and remains even after the device is no longer plugged in. Re-assigning the COM port to one of these ports is generally ok if you are certain that it's not being used.
No simple way to do so, although you could use a scope to verify the crystal is oscillating, if there is data in/out on pins 30/31 after powering up, and see if any other pins are active.
First thing to try is unplug all your USB printers, external hard drives, etc. You should be fine with your just your keyboard and mouse. I saw an HP printer prevent anybody else from talking on the USB, which confused the prop.
Then figure out if you have too many comports. It the last message siad the comport was higher than about 4, you should probably remove all the virtual com ports and start again. google "reset comports". The other devices with sort themselves out next time they are plugged in.
Next, what prop board are you using, and what are you powering it with? One older version board needed "the 100k resistor trick", these have become rare.
Lastly, the one Most like to solve the problem. Often its just a crappy power supply isn't delivering enough oomph to make the prop go.
Try these and let us know.
What are you doing lightbringer, yabbering all over the forum using old threads? I answered you on another old thread and here you are again. Mind your manners when you come to the table and we will see you get fed.
There are five of these identical posts (lightbringer's not Peter's). Ouch.
