Function Confusion — Parallax Forums
Function Confusion
ajwardajward Posts: 1,130
edited 2013-10-15 16:09 in Propeller 1
Hi All...
I know there's probably a simple answer, but I'll be darned if I can find it!
After getting my tracked vehicle running with the Stingray demo code, I've started using Kye's "PWM2C_HBDEngine" from the OBEX for more control. My code (See below) has functions to ramp up, ramp down and run forward and pivot turn to the right. Running the first three functions on the MSR1 board, Ted ramps up, runs forward for a bit, ramps down and stops. However, when I add the fourth function "pivot_rt", he ramps up runs forward, ramps down, but the vehicle never stops pivoting. What am I missing here?
Any wisdom appreciated!!!
Amanda
PS- Happy Monday!
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  _leftFW = 25
  _leftBW = 24
  _rightFW = 26
  _rightBW = 27
  _timeStepInMilliseconds = 20
  _updateFrequencyInHertz = 8_000
OBJ
  hbd: "PWM2C_HBDEngine.spin"
Pub Main
  ramp_up
  waiTcnt(clkfreq + cnt)
  run_fwd
  waitcnt(clkfreq + cnt)
  ramp_dn
  pivot_rt
PUB ramp_up | timeCounter, frequencyCounter
  ifnot(hbd.HBDEngineStart(_leftFW, _leftBW, _rightFW, _rightBW, _updateFrequencyInHertz))
    reboot
  timeCounter := ((clkfreq / 1_000) * _timeStepInMilliseconds)
    repeat frequencyCounter from 0 to 1000 step 50
      hbd.leftDuty(frequencyCounter)
      hbd.rightDuty(frequencyCounter)
      waitcnt(timeCounter + cnt)
return
PUB run_fwd | timeCounter, frequencyCounter
    reboot
    repeat 2
      frequencyCounter := 1000
return
PUB ramp_dn | timeCounter, frequencyCounter
    reboot
    repeat frequencyCounter from 1000 to 0 step 50
return
PUB pivot_rt | timeCounter, frequencyCounter
    reboot
    repeat 2
      hbd.rightDuty(-frequencyCounter)
return
  • Mark_TMark_T Posts: 1,981
    edited 2013-10-07 13:37
    ajward wrote: »
    Hi All...
    I suspect you aren't allowed a negative rightDuty value?
    edited 2013-10-07 14:39
    Amanda after your pivot_rt method you should probably run your ramp_dn method to stop. Also you only need to run the engine start instructions once in the beginning of your code. The methods automatically return so you do not
    need to write return in each one unless there is a variable you would like to return.
  • ajwardajward Posts: 1,130
    edited 2013-10-07 15:16
    Mark_T wrote: »
    Thanks for your reply Mark!
    Yeah... I guess that has to be it. I've used that obex module before and I could swear I've sent negative values to the function before. Of course, I can't find my previous code to verify. <grumble>
    Anyhow... thanks again!!!!
    Amanda
    edited 2013-10-12 14:48
    @Dave - Thanks for that. Working on the little beastie right now. I'll give your ideas a try!!!
    Amanda
    edited 2013-10-12 15:03
    ajward wrote: »
    I'm pretty sure you're right about negative values being valid. I think negative values put the motor in reverse.
    It would be easier if you attached the code as an archive and then we could also see the child object.
    edited 2013-10-12 15:22
    In the object she is using the values for leftduty and rightduty go from -1000 to 1000 to go either way.
    Edit: Duane is right you have to put a negative # to go one way and a positive # to go the other with 0 being stop.
    edited 2013-10-12 17:55
    After looking again at your pivot_rt and ramp_dn methods your ramp_dn method first puts the wheels at full speed before ramping down. So you might not want to put ramp_dn after pivot_rt. You can stop the wheels by -
    hbd.leftduty(0)
    hbd.rightduty(0)
    I had never used Kye's object before so I tried this example on my Stingray and it works. It also shows another use of return to escape a repeat loop. Maybe you can get some use from it.
    Con
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
       _leftFW = 24
       _leftBW = 25
       _rightFW = 26
       _rightBW = 27
       '_timeStepInMilliseconds = 10
       RAMPING = 5  '*100us delay per step duty cycle
    Var
      long left_old, right_old
    Obj
      hbd : "pwm2c_hbdengine"
    Pub Main
      hbd.hbdenginestart(_leftFW, _leftBW, _rightFW, _rightBW, _updateFrequencyInHertz)  'start pwm
      Wheels(-500, 500)    'forward @ half speed
      waitcnt(clkfreq+cnt) 'pause before setting wheels again
      Wheels(500, -500)    'reverse @ half speed
      Wheels(500, 500)     'turn left @ half speed
      Wheels(-500, -500)   'turn right @ half speed
      Wheels(0, 0)         'stop
    Pub Wheels(left, right)
      repeat
        if left < left_old                       'increment or decrement by one to new speed'
          hbd.leftduty(--left_old)
        if left > left_old
          hbd.leftduty(++left_old)
        if right < right_old
          hbd.rightduty(--right_old)
        if right > right_old
          hbd.rightduty(++right_old)
        if left_old == left                      'check if both left and right wheels-
          if right_old == right                  '-are @ new speeds and return from-
            left_old := left                     '-this method when met
            right_old := right
            return
        waitcnt(clkfreq / 10000 * RAMPING + cnt) 'RAMPING * 100us pause per step duty cycle
