How can i use one io port for more than one sensor
I am looking for a way to use one io port (eg on a STAMP 2 processor) for two or more sensors. The nummer of io ports on the different processors (STAMP,Propellor, ...) is limited and i wonder if there is an IC that i can use to direct the io port to different sensors?
For input I/O expansion, also look at the 74HC165 shift register. They're cheap and easy to use. There are plenty of coding examples in the StampWorks Manual and in one of the Nuts and Volts Columns in Parallax's archive.
