hello_p2
I will be getting an addon board for my NanoP2 from Mr. Potatohead in a few days, but this is driving me nuts.
I don't know who posted the following code, but after making the appropriate changes, it runs just fine with the new configuration on my bare NanoP2.
On the other hand, I have tried every variation I can think of in both Spin and P2ASM using the new configuration and the new serial code from Chip and it all seems to hang. I can get the monitor back by resetting the terminal. Does anyone have a working new serial "hello" in Spin that I can try? I don't really care that it doesn't work on my bare Nano, but I would be tickled if that it does. (If you think about it... have a compulsory need for addon boards would be a really good thing if they were for sale:)
Rich
' mostly stolen from Chip's P2 ROM monitor CON BASE = $e80 CLOCK_FREQ = 80000000 BAUD = 115200 SERIAL_TX = 90 ' must be in the port c SERIAL_RX = 91 CR = $0d LF = $0a DAT byte 0[BASE] org start reps #$1F6-@reserves+@start,#1 'clear reserves setinda #reserves mov inda++,#0 setp tx_pin mov dirc,dirc_mask 'make tx pin an output jmptask #rx_task,#%0010 'enable serial receiver task settask #%%1010 ' wait for the user to start the terminal emulator mov x,#5 :pause getcnt w add w,freq passcnt w djnz x,#:pause setptra hello_addr 'print hello message call #tx_string 'print hello/error message setptra hello2_addr call #tx_string idle call #rx cmp x,#CR wz if_nz jmp #:next call #tx mov x,#LF :next call #tx jmp #idle ' ' ' Print string (@ptra) ' tx_string rdbyte x,ptra++ 'get chr tx_string_ret tjz x,#0 'if 0, done call #tx 'other? jmp #tx_string ' ' ' Transmit chr (x) ' tx shl x,#1 'insert start bit setb x,#9 'set stop bit getcnt w 'get initial time :loop add w,period 'add bit period to time passcnt w 'loop until bit period elapsed shr x,#1 wc 'get next bit into c setpc tx_pin 'write c to tx pin tjnz x,#:loop 'loop until bits done tx_ret ret ' ' ' Receive chr (x) ' rx call #rx_check 'wait for rx chr if_z jmp #rx rx_ret ret ' ' ' Check receiver, z=0 if chr (x) ' rx_check or rx_tail,#$80 'if start or rollover, reset tail getspb rx_temp wz 'if head uninitialized, z=1 if_nz cmp rx_temp,rx_tail wz 'if head-tail mismatch, byte ready, z=0 if_nz getspa rx_temp 'preserve spa if_nz setspa rx_tail 'get tail if_nz popar x 'get byte at tail if_nz getspa rx_tail 'update tail if_nz setspa rx_temp 'restore spa rx_check_ret ret '************************ '* Serial Receiver Task * '************************ rx_task chkspb wz 'if start or rollover, reset head if_z setspb #$80 mov rx_bits,#9 'ready for 8 data bits + 1 stop bit neg rx_time,period 'get -0.5 period sar rx_time,#1 jp rx_pin,#$ 'wait for start bit subcnt rx_time 'get time + 0.5 period for initial 1.5 period delay :bit rcr rx_data,#1 'rotate c into byte add rx_time,period 'add 1 period passcnt rx_time 'wait for center of next bit getp rx_pin wc 'read rx pin into c djnz rx_bits,#:bit 'loop until 8 data bits + 1 stop bit received shr rx_data,#32-8 'align byte pushb rx_data 'store byte at head, inc head jmp #rx_task 'wait for next byte '************* '* Constants * '************* hello byte CR, LF, "Hello, Propeller II!", CR, LF, 0 hello2 byte CR, LF, "Hello again, Propeller III!", CR, LF, 0 hello_addr long @hello hello2_addr long @hello2 rx_pin long SERIAL_RX tx_pin long SERIAL_TX dirc_mask long 1 << (64 - SERIAL_TX) period long CLOCK_FREQ / BAUD freq long CLOCK_FREQ '************* '* Variables * '************* reserves w res 1 'main task x res 1 y res 1 z res 1 rx_tail res 1 'serial receiver task rx_temp res 1 rx_time res 1 rx_data res 1 rx_bits res 1
Rich
Andy
In your Spin2 code you have the following line
I assume this means set direction of Port C bit 26
The ".txpin" is the modulus of 90/32?
Where did you get this info on Spin2?
Cheers
Brian
I went ahead and attached it
I'll take a look... Thanks Potatohead
Thanks Potatohead
You've given us a good starting point.
Cheers
Brian
Chip has a Spin2 example in the ZIP (serialio.spin). From that I got the [.bit] syntax and the serina, serouta handling.
The rest is guessing and trial and error and - yes I also looked into the PNUT.exe with a hex-viewer.
I think the syntax with the dot for bits is because in Spin2 you can access the bits of every variable, not only the OUTx, DIRx etc.
Chip has included Spin commands for most new PASM instructions with the same name, so the PASM reference helps also.
But it is not so much fun to code in Spin2 at the moment, because you never know what works and what not. It's more debugging than coding.
@potatohead
Thanks for the ASCII extraction. much better than what I have done.
But I think you need to remove the first character of most Spin command words, they specify some kind of command type.
Andy
Edit: I did a lot of them.
Re: ASCII
On UNIX, just use "strings pnut.exe > text.txt" Microsoft published one that works about the same way, and it can be found on Technet. That's what I used as I'm on a Win32 machine right now.
