ActivityBot - Problem with Trimming
Earl Foster
Purchased an ActivityBot and I am going through the lessons and I am in the Navigation tutorial. When I run the "Test for Trim" program my right wheel burst forward in spurts causing the Bot to go into a counterclockwise circle. It makes a complete circle before the problem stops. I have adjusted the trim values but the right servo continues to burst in spurts. Everything looks to be in order electrically. I tried new batteries. I also tried reversing the servo and encoder connections. No change in behavior except it runs backwards with the same servo bursting. Any ideas why or how I can fix this problem? Thanks
Did the calibration steps work for you? Have you dumped the calibration data from your eeprom?If so, compare it to the good & bad runs that I attached to post #7 of the above thread. And, check the alignment of the encoder LEDs through the holes in the wheels.
I hope this helps!
dgately
