access to RESn pin on Prop Proto USB board?
ags
Before sending boards for fabrication I'd like to verify that I the timing and drive strength of the Propeller RESn pin (with BOEn active (low)) will be sufficient to properly reset other components in my design at power up.
Has anyone found a reasonable way to access this signal on the Prop ProtoBoard USB? It's routed to the FTDI chip but I don't see any way to connect to it. (I searched for a schematic online but it appears this board is no longer available - perhaps due to the USB reset problem?)
Thanks.
Thanks.
It doesn't look promising - unless I can get to the connections to the reset switch from the backside; I don't have the board with me at the moment so I can't check until later.
