Measuring the surface speed of a bearing
I have a 7 mm wide x 22 mm OD bearing whose outside surface is in contact with a spinning wheel. I would like to measure the rotational speed of the bearing using some type of optical encoder. Maximum speed is in the 100's of RPM but I am also interested in measuring very slow speeds down to about 1-2 RPM. The bearing is stainless steel so I was wondering if some of these IR optical encoder detectors would be able sense the smooth surface rotation if I painted small black lines on the outer surface or even side of the rim (say 30 to 60 lines). Does anyone know if these optical encoder sensors can use metal surface/painted surface for detection?
The bearing is 22 mm OD so the backup plan will be to glue on a 1" OD optical wheel.
If a slotted wheel is used should one of these type of sensors be used with it? IIRC, the S2 has uses a small version of the photo interrupter sensor I just linked to.
Thanks everyone!
I saw a demo at the sensor expo a couple years back that use this principle. The guy said it could sample faster than the shaft could spin. Of course, the unit he was showing cost a big pile of money. I suppose the sampling frequency of the optical mouse parts wold be the controlling factor.
