Bs2 xbee
Hello everyone. I have 2 boe bots bs2 processor and 2 xbee series2. I read somedocumantation about the wrring. Unfortuanatelly i havent managed to succed. The program that i wrote for the sender is :
Baud con 84
Tx pin 14
Rx pin 15
Temp var byte
Temp= 2
Do
Serout tx, baud, [temp]
Pause 1500
Loop
And for the one receiving:
Baud con 84
Tx pin 14
Rx pin 15
Temp var byte
Temp= 2
Do
Serin rx, baud, [temp]
Debug dec3 temp
Pause 1500
Loop
Baud rate is 9600. If that is of any help. I will admit that i havent done any settings at the xbee.
Please help me
Thank you in advance!
I have used this wiring. Tryed out both 14 and 15 as tx-rx still nothing. I would appriciate if someone could post a wiring picture.
For those who may ask what i want it for: trying to build an rc car in which on has all the sensors and one has the motors. Xbees are for communication
Baud con 84
Tx pin 14
Rx pin 15
Temp var byte
Temp= 2
Do
Pause 1500
Loop
Baud con 84
Tx pin 14
Rx pin 15
Temp var byte
Temp= 2
Do
Debug dec3 temp
Pause 1500
Loop
Please help me
In order to load the coordinator firmware onto one XBee, you have to connect it to a PC running the XCTU software. XCTU is a nice program that lets you check the exact model and firmware and settings and to get things set up.
There has been a lot of discussion of the differences between series 1 and series 2 on the forums. In general, series 1 modules are easier than series 2 to start with out of the box. Also see the new video starring Chris Savage from Parallax, comparing the different modules.
