integer to string in DAT section — Parallax Forums
ShawnaShawna Posts: 508
edited 2013-09-30 09:38 in Propeller 1
I would like to take a long variable and convert it into a string.
For instance if I have a value of 989, I would like to store it as a string in the dat section like this.
str byte " 98.9"
Is there an easy way to do this?
I can break the value down into whole numbers and decimals like this
temp := 989
tempDec     := temp // 10
tempWhole := temp / 10
The range is going to be +/- 200.0, so no matter what the value is I need to have 6 characters store in the dat section.
Shawn
    edited 2013-09-28 23:46
    Take a look at the SimpleNumbers object in the Propeller library. IIRC, there's a number-to-string conversion method there.
  • ReachReach Posts: 107
    edited 2013-09-29 20:33
    Temp := 98.9
    Temp would have to be a long but converting it to a few bytes can be done later
    as long as the math is done correctly why not just do like that?
    Temp := 98.9 would result in the following value being stored:
    1120259277 (Decimal)
    42C5CCCD (Hexadecimal)
    01000010110001011100110011001101 (Binary)
