100hz fixed frequency variable pwm
i have been bouncing around different solutions to a problem. I have been trying to make a variable frequency & variable duty cycle driver for 12vdc proportional solenoid. I have come to the conclusion that i only need adjustable duty cycle with a fixed 100hz frequency. The variable duty cycle is really only to set a % of flow for a proportional electrohydraulic pump control. Once i get it to the output i need, it will stay fixed, except ramping up & down to start & stop it. i have need for three of these signals to control one piece of off road equipment. And i need them to be very stable.
i was going to use some simple 555 based, but i also need serial lcd screen to show RPM of the shaft speed these pumps control. I have Quickstart propeller, Bs2, PWMPAL, DV103H, all at my disposal. Can anyone help with a absolute for sure way to do this, as i have been trying all of these and getting no where. Have to have this completed by end of weekend...
Thanks for any help
i just tested a circuit that was like 344hz at 39 % duty cycle and output 4.24vdc, and that worked perfect.
