Activity bot abdrive.h encoder questions — Parallax Forums
Ray0665Ray0665 Posts: 231
edited 2013-09-30 11:03 in Robotics
void drive_getTicksMeasured
(.text+0x145): undefined reference to `_drive_getTicksMeasured'
note the underscore in front of drive not sure if it is me or a library problem.
I keep getting the above error from the following source code
drive_getTicksMeasured(&L_ticks, &R_ticks); /* get encoder readings since last sample*/
can anyone help?
Also what is the difference between the above routine and this one?
void drive_getTicksCalc
  • dgatelydgately Posts: 1,646
    edited 2013-09-27 13:11
    Looks like those functions have not been coded yet (in the most recent ActivityBot library, version: ActivityBot 2013-09-03b-1). Though they are declared in "../SimpleIDE/Learn/Simple\ Libraries/ActivityBot/lbabdrive/abdrive.h"... (excuse the Unix/Linux/Mac OS X path naming if you are a Windows user)
    Looking inside "../SimpleIDE/Learn/Simple\ Libraries/ActivityBot/lbabdrive/abdrive.c", you will not 'yet' find those functions.
    ActivityBot libraries are in-progress at this time, but I'm sure Parallax folks will read this post and advise. :innocent:
    The descriptions of these functions can be found in the HTML-based documentation that you'll also find inside the Simple Libraries directory with a path similar to: "../SimpleIDE/Learn/Simple\ Libraries/ActivityBot/Documentation\ abdrive\ Library.html".
    dgately
  • edited 2013-09-30 11:03
    Hello Ray0665,
    Thanks for asking. Those features are not yet implemented yet, but should be in the next version of abdrive (coming soon). My To-Do list is in the details section of ...\Documents\SimpleIDE\Learn\Simple Libraries\ActivityBot 2013-09-03b\Documentation abdrive Library.html.
    For now, if you want to get the current encoder ticks count, use void drive_getTicks(int *left, int *right).
    The abdrive control system compares the calculated distance to the measured distance and updates the servo output 50 times per second. The drive_getTicksCalc function will load the calculated number of ticks (target position) into the variables whose pointers you pass. Then, drive_getTicksMeasured, which is currently drive_getTicks, retuns the measured number of ticks.
    int leftDist, rightDist;
    drive_getTicks(&leftDist, &rightDist);
    print("leftDist = %d, rightDist = %d\n", leftDist, rightDist);
    Andy
