BasicStamp 2 vs 2sx memory size
So, while working with the Basic Stamp 2 I have found myself bumping up against the 500 instruction memory limit. I have now aquired a BS 2sx and I am still being informed that the EEPROM is full after only 500 lines of code. Am I misinterpreting something or doing something wrong? I expected to be able to write a program 8 times as long using the BS 2sx. Any help would be appreciated.
There is a Nuts & Volts article on multi-bank programming at the following link. I hope this helps.
http://www.parallax.com/downloads/nuts-and-volts-basic-stamps-volume-3
