Scroll Saw Motor Driver
The motor driver on my Craftsman Scroll Saw bought the farm.
The replacement driver board from Sears is $67.00 plus shipping, I can't bring my self to pay that for a board that will likely eventually die as well.
The factory was nice enough to grind part numbers off of critical components...
I replaced the triac for giggles, didn't help.
So it seems it's time for a project, I realize I'll spend way more in time and money, but I'll have a controller that's more robust and easier to maintain.
The saw has a PM DC motor with an AC tach attached to the shaft for speed feedback.
The controller is using a triac to feed a fullwave bridge with a freewheeling diode across the motor.
I'll likely use a propeller and use the tach feedback to do PID control of the motor speed.
I'd like to get some suggestions for the motor driver circuit.
I could use a triac feeding a rectifier like it does now, or I could rectify first and then use an SCR or mosfet.
Snubberless Triac or add a external snubber?
Any suggestions?
Chris Wardell
Any suggestions?
Chris Wardell
http://www.littelfuse.com/~/media/Electronics_Technical/Application_Notes/Switching_Thyristor/Littelfuse_Phase_Control_Using_Thyristors_Application_Note.pdf
C.W.
Good luck and keep us posted on how it goes.
Thanks ElectricAye.
I know I should just be pragmatic and buy the darn replacement, but who ever said I was pragmatic...
C.W.
You will have to convert your AC to DC to powere the motor. And you will have to figure out what voltage it wants to operate at. Is there an Amp rating on the unit? That would ballpark a maxium and probably is a bit over the actual motor current.
Nothing wrong with hacking what might become yet another junker without your inspiration.
No guts, no glory. If it is low power, you might just try a room light dimmer switch as a speed controller.
Here is a very general introduction... http://control2.net/p/picmicro-dc-motor-control-tips-n-tricks-w2788.html
That is an interesting read. I'm always pretty nervous when it comes to mains current, but this looks complete enough to maybe give it a try.
How much of the original circuit do you plan to reuse? Do you know which part(s) failed?
Thanks for the document link.
It is a brushed DC motor, no markings, no details on the Sears parts site other than that it's a motor...
The original controller has a Triac (BTA16-600B) driving a FW bridge made from FR307 (1000V 3A Fast recovery) rectifiers. It also has a FR307 across the output of the bridge as a flyback diode.
The nameplate rating on the saw is 120V, 1.6A, so we have some ballpark figures. The manual states 400 to 1600 SPM (strokes per minute), so we have operational limits.
I jumpered the across the triac A1 and A2 terminals and the motor runs, but at excessive speed, so I know the motor is good.
C.W.
I replaced the triac based on the most likely to be bad theory of shotgun repair techniques...no joy.
The diac the drives the gate has the part number ground off, replaced it with a likely candidate...no joy.
There are four small signal transistors, they all check OK.
There are two LM324's, really the only other actives that could be bad.
The power supply pins on the LM324's are at 15.7 volts, that seems reasonable.
I suppose I could replace the LM324's but I have this gut felling that won't help.
The remote potentiometer checks out, not much else left.
C.W.
I presume this is ONE direction of rotation, so the LM324 may have many outputs in parallel to provide more power. Is the motor running at 15-16 volts or at 115V?
http://images.search.yahoo.com/yhs/search?_adv_prop=image&fr=yhs-ddc-linuxmint&va=lm324+motor+control&hspart=ddc&hsimp=yhs-linuxmint
The motor is running from rectified 115V, based on the triac and diac it looks like it's using phase angle control to vary the speed.
The motor also has an AC tach output, the LM324's are likely using that to try to regulate the speed.
C.W.
Had a pool pump controller go out, thought it was the out transistor that controlled the relay went bad. Digital display still worked, but would reset when It activated the load. Replaced two electrolytic caps and all’s good now. I’m assuming the heat cooked the caps.
There are a few electrolytics, none of them are bulged or look bad in any way, there are also a few what look to be mylar or some type of film capacitors.
I haven't done any probing with the scope because this thing isn't isolated and I don't have an isolation transformer.
C.W.
Generally, the higher power devices are subject to the greatest stresses, so they fail first... unless there are other obvious issues (such as corrosion or heat stresses). Last year I sucessfully repaired my A/C controller board via reverse-engineering. But it became obvious that the cooling coils were leaking badly due to rust, so I replaced it this year.
I use a TV to VGA box for TV. My old one failed and replacement of the capacitors revived it for another two years. About a month ago, the digital chips went haywire and while I could get audio on all channels, the digital output would hang on one still image. So it too was finally replaced.
My wifi router failed. All that was required was a new wallwart. This seems a common lightning strike problem that causes many to buy a whole new router.
Switches and pots are other sources of failure, sometimes easy to resolve, sometimes impossible.
The main point is that I am getting an extra year or two of use via these DIY repairs. And I improve my ability to reverse engineer as I try more.
I'm going to try a few more part replacements this weekend.
C.W.
I did not have the exact value but had some that were slightly over rated in value and voltage. Might be worth a shot if you have some on hand.
Marty
It's double sided with a lot going on under components which makes it hard to trace.
I may slog through it an make a schematic but I'm going to try replacing the two electrolytic caps first.
C.W.
Here are some pictures.
C.W.
Marty
fthe electrolytics are obviously filtering a/c ripple, it would not hurt to increase the capacitance if you find you have bigger capacitors with the same foot print. It doesn't hurt to go to a higher voltage rating either. These upgrades will add life to the repair.
I strongly suspect that manufacturers provide caps that are intended to live short lives as many of the other parts just never fail.
Dave, it's dead as far as driving the motor, the power supply seems fine, 15.7V present on the LM324's.
If I jumper the A1 & A2 terminals of the triac the motor runs, so the rectifiers are OK.
The tach leads show a resistance of around 50 ohms, I measured 4.15 volts AC when running the motor with the triac jumpered.
I'm going to go ahead and trace everything out this weekend.
It is now a matter of being stubborn; way past the point of being pragmatic or saving any money...
Thanks for the help guys.
C.W.
Pretty much ready to punt and build a new controller.
C.W.
I decided it wasn't worth the time and set it aside.
The motor is Permanent Magnet DC, so the AC/DC speed controls made for universal motors will not work without adding a fullwave rectifier.
C.W.
