Select the text you want and press ctrl+c. I often have to press it several times before it works. You'll know when the copy worked because the selected text becomes unselected.
Yeah, I see now that it's a little fussy. You have to hold control, and while holding control, tap c. It's a little different than just ctrl+c. Thanks,
You can then paste the text into a text editor.
