Boe-Boost Battery Extender
I bought the 5 Cell Battery pack plus the single battery extender, Boe-Boost. The problem is the Boe-boost, has anyone actually got that thing inserted into the battery pack? So far, it has been a frustrating exercise in futility.
The thrifty Boe-Boost (#30078) allows you to add another cell in series with a 4-cell or 5-cell pack. Adding a 6th 1.2 V AA rechargeable cell to a 5-cell pack will supply 6 x 1.2 = 7.2 V.
IIRC, I ended up pushing both the two battery ends which connect to the Boe-Boost(BB) and the BB tabs into the other other pack all at the same time. It was a trick but I got it to work.
I think the BB would be easier to use on non-rechargeable cells.
Edit: Sorry Rick, I hadn't read you're post carefully enough. I'm glad my method agrees with the pdf.
Also, the Boe-Boost was designed aournd the four-cell battery holder. If the cells in the five-cell holder are closer together, the Boe-Boost tab spacing may not be optimum, so reports from the field are welcome on this point.
