Simple ways for person with no soldering skills, to connect two wires together?
Hello.
I have a friend, for which I built a specific device. It connects to his camera flash with 4 wires. All these wires are readily available inside his flash, and does not contain high voltage, so it should be reasonably safe for non-skilled person to connect some wires to it. The question is, how he can do it? He has no soldering gun/skills/etc. Wires are short enough, so they can't be pulled out, to strip the insulation. I have seen a special on wire clips, mainly used in automotive, where you place two wires into jacket, snap it, and blades cut insulation and connect wires together. Are such connectors available in miniature size, or maybe there may be any other simple solution?
Google "wire glue"
Are the wires in question solid or stranded? If stranded, you might be able to carefully insert a small length of 30AWG bare wire into the strands of one wire, and then gently (carefully) bend the wire over and insert it into the other wire making sure the exposed 30AWG area is small. Then "blob-solder" the two together.
Did that make sense?
I've not seen the self-biting clips mentioned in small sizes...but that doesn't mean they don't exist. Digikey? Mouser?
:frown:...well, now that a picture has been posted I see that my suggestion is totally irrelevent. Yeah - I agree with the others: have someone do the work for your friend.
Just pay a guy and have it done right and be finished.
I do know the clips that you mention for automotive wiring. They are very popular with trailer rental outfits as they allow them to connect into the tail lights and the brake lights involved in the existing car wiring without much effort. But they really are not the best solution ... just quick and easy.
You camera flash wiring is smaller and in a more tight space. Quality is more of an issue. Good wiring is both about good connections and good insulation. Those clips on the automotive wiring break existing insulation, but don't reseal it against moisture.. a big issue in automotive use.
To start out.
Consider what size wire you want to use 22 gage or 12 gage.
Can you cleanly bring wires out of the camera flash and then do the rest of your work outside?
Can you insulate your work inside the camera flash (with hot glue or epoxy or silicone or shrink wrap)?
If you are feeling a strong 'NO', maybe modifying this is not realistic.
Mods to existing technology become easier with experience. I now do things I would not dare to do 10 years ago. But the experience includes a lot of discovery by making things that didn't work or damaging items in ways that could have been avoided.
Can you avoid all and any heat damage to the camera flash while connecting wires?
By the way, no those automotive connectors are not made for smaller wire. But there is a snap connector for splices in telephone wire at about 22 gage. I have no idea of the gage or how appropriate these would be to the insides of a camera flash.. the telephone wire clips expect solid wire... not stranded. I don't think using them would be a good idea as insulation can make one think the wire is much thicker and more solid than it really is.
You might just find a second junker to practice on before you ruin a good piece of equipment... and maybe a friendship.
Can you find a jack and plug that would allow you to install the jack in his flash and the plug on your device and then he can plug/unplug as needed? (or some other suitable connector scheme)
Having/expecting him to solder it just sounds like a lot of trouble that could/should be avoided.
Best idea yet.
First Class package shipping is pretty cheap, and if it's too heavy for that then it's probably a very expensive flash unit and worth the few extra bucks for Priority Mail.
Thank everyone for the replies. Here are the answers.
I'm including the photo of flash guts for reference. You can see wires on top side going into other part of the flash. He needs to connect in parallel to orange, brown, red and black wires. The device I've built for him is completely standalone, and small enough (contains double sided PCB with two SOIC-16 IC's on both sides) to fit inside the flash (I have similar flash and already did the mod). I've immersed assembled device into liquid electrical tape, so only wires go outside now.
Sending flash via mail may seem to be the good idea, but problem is that I'm in Georgia and he's in Australlia. And since flash we're modding costs less than postage (and it is old and heavy), sending it... well, I consider it as last resort, if no solution found.
And for the jack & plug. The flash already has jack, but plug for it is proprietary and costs 3x more than flash itself
http://www.ebay.com/itm/Minolta-OC-1100-flash-cord-/121177792608?pt=Camera_Flash_Accessories&hash=item1c36c26060
Maybe your friend could very carefully pare away a small section of insulation on each wire using a fine scalpel and a jewellers loupe/magnifying glass. Your friend would only need to pare away a couple of millimeters.
Once this is done they could then tightly wrap the stripped end of the new wire around the existing wire.
The join can be insulated with a carefully placed blob of hot glue (applied/manipulated with a pin).
This is extremely fiddly and requires a good deal of patience but it can be done.
You can likely use it to push aside the insulation for 1/8th to 1/4 inch, wrap another wire around and solder. Then cover it with a dab of silicone for insulation.
I do understand that there is a plug you don't want to buy.
And there is postage you don't want to pay.
But if you don't want to buy tools and materials as well or pay someone who has them.... it seems as if you are looking for a problem more than a solution.
Practice the mid-wire stripping before you do the real thing on some scrap wire. When in doubt, assume the existing copper wire is bigger than it is as nicked insulation will usually seperate without going all the way down to the copper.
Who's gonna do it? Paid or unpaid? I dunno, we can't push a techie through the internet to rescue people. At least not yet.
This is a non-commercial project, the friend came up with idea, and I did it in hardware. This is advanced optical slave trigger for old, film-age minolta camera flashes, to allow their ussage with modern digital cameras. As most photographers in the world, my friend also has little knowledge in soldering or electrical wiring. But the circuit might be usable for other photographers, if it will be simpler to install it.
It's not as if it was rocket surgery or expensive.
Plus, once they have got going they will realize all the other things they could be doing with their new found skill. Soon they will be wondering how they managed to live such a long an miserable life without a hot soldering iron permanently in hand. Perhaps Propeller projects will start blossoming forth and a whole new world opens up for them...
Spoon feeding is not doing them a service.
For instances, I just ordered a used book from the USA for less than $20 USD, and I have to pay $20 in shipping. It took me several months to decide to buy it... and a lot of shopping locally. This is just the global reality... things from afar create either more costs or other problems.
And I have friend in San Francisco that is 77 and needs Linux reinstalled on her eeePC, but she doesn't want to pay anything and gets angry and frustrated when the discussion turns to doing-it-herself. She has gone to local Linux User Group meetings, but they are equally put off by her helplessness. I can send her LiveCDs, but it is nearly impossible to talk her through the installation.
One last option
You might be able to use a screw connector or a crimp connector of some sort. But I suspect you will have to cut the wires, strip the ends in preparation. Then bunch the three ends together and secure. Can you find something appropriate and mail it to the other person for less than $2 ?
People here are recommending soldering because it is a durible, low resistance connection... probably the best over time.
Using clips, screw connectors, or crimp connectors can work, but they are higher resistance and often more subject to problems over time. But, at some point you are going to have to cut into the wires to determine the wire size and what might work. That is pretty much a point of no return.
We all run into the reality that the manufacturers do their best to NOT allow the user to modify a device. They would much rather have you buy a new one from them.
It sounds like the flash units are cheap enough that even if he messes one up learning it's not a big deal.
