Basic Stamp Mini Game
Test your reflexes using the mighty BS2
How it works:
0. Connect a button to P10 (pulled low when closed), Connect LED to P0, Connect Piezo to P1
1. Change Skill Level Variable in code if needed
2. Run the code below on your BS2
3. When the LED is on it is the beginning of the round (also determining random pause time)
4. Press the button to Start (LED goes out)
5. Wait for the LED to flash when it does press button to win!
6. If you miss or press to soon you lose round
6. Debug terminal keeps score
Build the circuit as pictured.
Use this code:
Have fun!
How it works:
Use this code:
'{$STAMP BS2}
'{$PBASIC 2.5}
' -----[ Program Description ]---------------------------------------------
' Test your reflexes BS2 game.
' Button is pulled low on pin 10, Use LED and resistor on pin 0, connect
' piezo buzzer to pin 1.
' -----[ I/O Definitions ]-------------------------------------------------
B01 PIN 10 ' Button
LED PIN 0 ' LED
BUZZER PIN 1 ' Piezo
' -----[ Variables ]-------------------------------------------------------
SkillLevel VAR Word ' Skill level Varibable
PValue VAR Word ' Pause value Varibable for random pause
Counter VAR Word ' Counter Varibable for random LED flash
Won VAR Word ' Wins Varibable for score
Lost VAR Word ' Losses Varibable for score
' -----[ Init Setup ]------------------------------------------------------
Won = 0 ' Initialize Score Variables
Lost = 0
SkillLevel = 150 ' Set skill level here (lower is harder)
' ~100 minimum for most push buttons
' -----[ Program Code ]----------------------------------------------------
DEBUG CLS ' Clear the debug terminal
DEBUG "Skill Level "
DEBUG DEC SkillLevel, "! " ' Display skill level variable
DEBUG "Press Button to Start Round "
DEBUG HOME, LF, "Won: " ' Show initial score
DEBUG HOME, LF, LF, "Lost: "
game:
DO ' Game start
DO UNTIL B01 = 0 ' Loop until button is pressed
HIGH LED ' LED on
RANDOM PValue ' Randomize PValue Varibable
LOOP
PAUSE 500 ' Give time for button release
LOW LED ' Turn off LED
GOSUB randompause ' Begin randompause subroutine
GOSUB flash ' Begin flash subroutine
LOOP
randompause: ' Loops button input while waiting for random time
DO UNTIL PValue < 101 ' to pass before flashing LED
PValue = PValue - 10 ' Runs down random pause timer fast
IF (B01 = 0) THEN GOTO lose ' If button pressed before LED flash, lose round
LOOP
RETURN
flash: ' Flashes LED for skill level time
FOR counter = 0 TO SkillLevel
HIGH LED
IF (B01 = 0) THEN GOSUB win ' Detects button press for win
NEXT
GOSUB lose ' No button press, lose
lose: ' Lose subroutine
lost = lost + 1 ' Update score
DEBUG DEC lost, " "
FREQOUT buzzer, 500, 3000 ' Play lose melody
FREQOUT buzzer, 1000, 2700
FREQOUT buzzer, 1500, 2500
PAUSE 1000 ' Pause a second
GOSUB game ' Go back to game start
win: ' Win subroutine
LOW Led ' Turn off LED
won = won + 1 ' Update score
DEBUG DEC won, " "
FREQOUT buzzer, 500, 5000 ' Play win melody
FREQOUT buzzer, 100, 5500
FREQOUT buzzer, 1000, 6000
Have fun!
