Providing power to easy drivers and hobby servos?
Hey all - I have a project where I will have two Easydriver boards and two hobby servo motors and I want to drive all this from a Propeller Mini board
so in testing I've hooked up a wall wart to one of the easy drivers and pulled 5V off of that to power the Prop Mini
my question is what's the best way to get power from the wall wart to the other easydriver and two hobby servos - should I just splice the wires or is there a more elegant way?
Thanks!
Jamie
Thanks!
Jamie
She got the thing at a local electronics store and it wasn't very expensive. She's really good at finding things.
Sandy
If your servos are small and your wall-wart powerful (but not over the voltage your servos can handle) then you might be okay. I say splice (but use heat shrink over the joints) of buy or make a connector like Sandy uses.
If your servos are powerful and your wall-wart not so much, then you might need a separate power supply for your motors.
If the prop keeps reseting as servos or motors start to move, it's a sure sign you need a better power supply arrangement. If you have more than one power supply, make sure you have a common ground connection among them (connect all the "-" power lines together).
Cool, I was going to build something like this in a box, but this would be a lot cheaper (and probably quicker considering how long it takes me to get around to doing something). I found a lot of them on eBay by searching for "DC power splitter". Many of the listings don't specify the actual connector size, but some do. I'm guessing 2.1mm is pretty much standard on CCTV equipment.
