BS2e v1.1 vs v1.2 serial comm
I have taken over a project that was done a few years ago. The stamp intercepts the the serial communications between a control application running on a PC, and an embedded microprocessor. The stamp program display some of this serial data on an LCD screen. I can program the old PCB, which had the stamp soldered in place, with some updated software and it works perfectly. I have a second PCB that didn't have a stamp on it. I ordered some new stamps and put one on the second PCB. After programing that stamp with the same software it displays the text that is hard coded into the software on the display, but won't display the data it is supposed to be getting from the serial port.
The stamp that works properly is a v1.1, the other is v1.2. Is it possible to put the v1.1 firmware on the newer stamp? Are there any changes in the serial port setup or usage between v1.1 , and v1.2?
I have limited experience with pbasic. Any help would be greatly appreciated.
Terry
Terry
According to the docs, the only change between the 1.1 and 1.2 versions is that an internal brownout detector is disabled.
Nothing that should affect serial at all.
http://parallax.com/sites/default/files/downloads/BS2E-IC-Firmware-Revision-Details-07-2007.pdf
Are you certain that that other PCB is OK?
Fairly certain. The guy I inherited the project from says it worked before he pulled the stamp. This one was in a socket so I wouldn't expect there would have been any damage. I may need to go back to the schematics and trace the circuit.
I was really hoping it would be a simple firmware change. Thanks for your help.
Terry
Are you using the same version BASIC Stamp Editor as was used originally?
Do the files have $STAMP and $PBASIC lines in th start?
This is an 'e' model. The important change from the stock BS2 to this one is that it has 8 separate Program memories.
Are you loading all the program files to the BS2e?
(Look for a command 'RUN' with a number after it in the main file to see if other Program memories are used)
I'm not sure. Since I made some changes to the original code and loaded it into the old board without a problem I didn't think this could be an issue.
It has the $STAMP directive, but no $PBASIC directive. I'm using ver. 2.5.3 of the editor. With no directive how dose it know which version of PBasic to use?
I have 3 files loading into memories 0, 1, and 2. The main runs program memory 1, the memory 1 file runs program memory 2, and the memory 2 file runs program memory 0. They show three separate status bars when I use the 'run' tool to load them. I have seen the run window close with the last status bar being completely filled in. Usually when that happens I hit run again just to be safe.
That actually brings up a question I should have asked before. There is a "Generate Object Code" menu item. I'm wondering if I need to use that to change the version of PBasic on the stamp.
1 is only used for BS1
If it doesn't have the directive it will default to using PBASIC 2 syntax.
There may be something special going on with the jumper wires.
Have you recreated them on the 'new' PCB?
Can we have a photo of the boards?
Thank you, to everyone that helped. Thank you, Gadgetman in particular. I learn enough to move ahead with a little more confidence. It's also nice to know that the stamp community is responsive to noob questions;-)
Terry
BTW: I can't find a way to mark this thread solved.
The difference is quite significant...
A Newbie is a newcomer, just beginning to learn...
A Noob, though... Isn't interested in learning, often thinks that he's great and that he can do no wrong...
(I play World of Tanks... I hunt Noobs... It's fun... )
