ActivityBot with SONY Remote
Andy Lindsay (Parallax)
The Navigate With Infrared Flashlights tutorial for the ActivityBot was added to the rest of the ActivityBot tutorials on Friday:
http://learn.parallax.com/activitybot
http://learn.parallax.com/activitybot/navigate-infrared-flashlights
Here's a sneak peek at a related project that's coming soon to learn:
Circuit
http://learn.parallax.com/activitybot/build-ir-sensor-circuits
...although you can just use the IR receiver connected to P10.
Libraries
Copy the SONY Remote folder inside the attached zip to ...Documents/SimpleIDE/Learn/Simple Libraries/
Make sure you're running the latest version of SimpleIDE (0.9.43).
Restart SimpleIDE if it's running.
Test Code
Use the New Project button to create, name and save a new project.
Paste this code, then click Run with Terminal.
Point your remote at your ActivityBot and try pressing its various buttons. Verify that the digit keys match what's displayed as you press and hold them.
Navigation Code
Repeat the test code steps, but this time, use the Load EEPROM & Run button.
Unplug from the programming cable, and press and hold buttons to control. 2 or Channel up are forward, 8 or channel down are backward. 4 or volume down are turn left, 6 or volume up are turn right, and 1, 3, 7, and 9 are pivot keys.
Circuit
Libraries
Test Code
Test SONY Remote Keys.c
#include "simpletools.h" // Library includes
#include "sonyremote.h"
int main() // Main function
ir_tLimit(1000); // -1 if no remote in 1 s
while(1) // Repeat indefinitely
print("%c ir key = %d%c", // Display key pressed
HOME, ir_key(10), CLREOL);
pause(100); // 1/10 s before loop repeat
Navigation Code
ActivityBot SONY Remote Control.c
#include "abdrive.h"
int key; // Remote key variable
int main() // Main funciton
freqout(4, 2000, 3000); // Start beep
drive_setRampStep(12); // 12 ticks/sec per 20 ms
ir_tLimit(50); // Remote timeout = 50 ms
while(1) // Main loop
key = ir_key(12); // Get remote key code
if(key == 2 || key == CH_UP) // 2 or CH_UP -> Forward
drive_rampStep(128, 128);
if(key == 8 || key == CH_DN) // 8 or CH_DN -> Backward
drive_rampStep(-128, -128);
if(key == 4 || key == VOL_DN) // 4 or VOL_DN -> Left turn
drive_rampStep(-128, 128);
if(key == 6 || key == VOL_UP) // 6 or VOL_UP -> Right turn
drive_rampStep(128, -128);
if(key == 1) // 1 -> Left forward pivot
drive_rampStep(128, 0);
if(key == 7) // 7 -> Left backward pivot
drive_rampStep(-128, 0);
if(key == 3) // 3 -> Right forward pivot
drive_rampStep(0, 128);
if(key == 9) // 9 -> Right backward pivot
drive_rampStep(0, -128);
if(key == -1 || key == MUTE) // no key or MUTE -> stay still
drive_rampStep(0, 0);
I ONLY HAD TO CHANGE
TO
key = ir_key(10); // Get remote key code
DUE I HAVE CONNECTED THE IR_DETECTOR IN PIN 10
MY BEST REGARDS AND HAVE A GOOD DAY
ENG. JESUS PEREZ CARREÑO (From Mexico)
