How to prevent voltage glimpses on BS2 pins on power-up?
Hello.
I have a simple motion sensor setup using basic stamp, so when motion is detected, the stamp enables the flash and camera, to take photo. The flash is connected to BS2 via 2N3904 transistor, which, via 470 ohm, is connected to BS2 PIN. The problem is, when I turn on the power, a small glimpse of voltage occurs on BS2 output, which is enough to trigger the flash. How can I solve this?
