Got Dynamixels? — Parallax Forums
Got Dynamixels?
JonnyMacJonnyMac Posts: 9,834
edited 2013-09-15 13:10 in Propeller 1
If you do, would you mind looking over my object and giving it a whirl? Thanks!
Oh... even if you don't have Dynamixels, any constructive feedback is appreciated.
[Edit] I have tested most features and everything seems to work as it should -- just looking for thoughts. Dynamixels are neat, but somewhat tricky; I'm hoping this object helps those wanting to dive into them.
[Edit] Updated driver attached to post #4 (below)
    edited 2013-09-10 12:42
    I'll dig my Smartarm out and give your code a try.
    edited 2013-09-10 13:32
    Jon I messed up my first post to this thread so I deleted it. I haven't tried all of your functions but I did write this which will turn off the torq for servo#1 and then display the current servo position and temperature in Celsius.
    Con
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
      ID = 1              'servo id#
      DP = 0              'servo port pin
    Var
      long addr, freq
    Obj
       jm : "jm_dynamixel"
      pst : "parallax serial terminal"
    Pub main | i
      pst.start(57_600)
      jm.start(DP, 1_000_000)
      jm.wr_byte(1, $18, 0)
      repeat
        pst.char(1)
        pst.str(string("Position = "))
        pst.dec(jm.rd_word(ID, $24))
        pst.chars(32, 5)
        pst.str(string(13, 13, "Temp     = "))
        pst.dec(jm.rd_byte(ID, $2b))
        pst.chars(32, 5)
    zip
    18K
    jm.zip 18.4K
  • JonnyMacJonnyMac Posts: 9,834
    After chatting with Kyle at Trossen robotics I came away with the impression that Dynamixels really don't want to deal with more than about 30 packets per second. I rewrote my X/Y report (for a head mechanism a friend is working on) so that it reads the entire contents of the Dynamixel RAM in one packet. The updated driver includes simple methods for pulling bytes and words from any buffer (without worry of alignment).
