Simple Harmonic Motion
And now for something completely different:
A beautiful demo of several pendulums swinging slightly out of phase. Hard to believe it cycles through all that and comes back to a nearly perfectly synchronized start position, but the video looks legit to me. Must have taken quite a while to calibrate all of those string lengths.
A slightly more surprising experiment is "coupled harmonic oscillators" where energy is transferred back and forth between two pendulums each one coming to rest at regular points in time whilst all the energy in the system causes the other to have maximum amplitude.
As in this nice demo by the wonderful Professor Roger Bowley http://www.youtube.com/watch?v=izy4a5erom8
You can make coupled oscillators with two resonant LC tank circuits where a week coupling between the inductors transfers the energy from tank to tank. It's kind of fun to set that up in a SPICE simulation as well.
http://www.arborsci.com/pendulum-wave
Check out the video about 2/3 down the page
I don't think the quite it. The slowest period isn't too far off from the fastest. I think the ratio between the various periods are made up of reasonably sized whole numbers which allow the phases to realign every so often.
If I had seen this demo before I had done my 32 servo demo, I would attempted something like this as part of the demo. As it was, I did have the servos move each a bit out of phase from the others to give a bit of a wave motion.
I'm sorely tempted to rig up 12 servos with sticks and fluorescent balls to give this a try with servos. I think the software would be trivial (by reusing the 32 demo code) but I'm not keen on putting the hardware together.
As much as I like watching servos move, I think a demo like this with servo would loose a lot of the mystic supplied by real pendulums.
You chicken, McFly?
When I say a multiple I wasn't thinking integer multiples. I was thinking along the lines of strings on a musical instrument. The string an octave lower is a multiple of 2 of the higher octave string, while strings between the two octave string are a fractional multiple greater than 1, but less than 2.
Go to http://www.falstad.com/circuit/ and on the pop-up, go to File->Import and paste:
