Wiring a potentiometer
Amoungst some parts which I ordered for my current project is a potentiometer. It has 3 prongs/pins. These are not spaced the same as the holes in my solder-less breadboard, and they seem just a little too wide for the breadboard holes anyway. I am wondering if they are meant for either mounting (putting the prongs through holes in a circuit board and bending, or if some kind of connector to fit onto. There are small holes above the pins/prongs but they are so close to the body that he middle hole doesn't go all the way through, and is blocked by a thin (maybe 1/32 inch) layer of translucent plastic that encases the base of the pot. So in order to use it for soldering, I would have to get out my Dremel tool and drill the hole the rest of the way through the plastic outer coating. I am hoping that the pins/prongs are for a connector so that I don't have to solder wires directly to it.
H.
H.
I'd be reluctant to drill into the case of the pot. I often solder some hookup wire to pins that don't quite fit to make them easier to plug into a breadboard.
I'm not aware of pots designed to be plugged into sockets though I wouldn't be surprised they exist. I would be surprised if your pots were intended for sockets.
Do you have a link to the part you're talking about?
http://www.ebay.com/itm/UN3F-5X-150mm-RC-Servo-Extension-Cord-Cable-Wire-Lead-for-RC-Car-Helicopter-/271228452856?pt=Radio_Control_Parts_Accessories&hash=item3f2679bff8
http://www.robotroom.com/Trimpots.html
There are three views of one in a picture there (down the right side of the second photo).
Parallax 3 wire connectors are good for connecting pots and other things. I just cut them in half to make two cables with a plug on one end and stripped wire to be soldered on the other.
Attachment not found.
I would strip the insulation for 1/4" to 3/8" off the end of a wire and wrap the wire around one of the pins, repeat for the other pins, then solder the wires to the pins.
Do not drill out the middle hole. It's not necessary.
Per Mike, don't drill them out. Neither necessary nor desirable.
But thanks. I will solder to the pins, or maybe solder to the holes on each side as those are clear, and solder to the middle pin.
H.
