virgule
Heater.
Today's interesting fact:
That symbol we use to separate elements in a path specifications in Unix and URLs, "/", the "forward slash" or is it "back slash" I can never remember which is forward and which is backward, has a name: "Virgule". http://www.thefreedictionary.com/virgule
Thank God for that. I no longer have to worry about trying to remember forward from backward slash, I can just say what I mean, "Virgule home virgule username" and everyone will know what I mean.
Curiously "Virgule" seems to be derived from the latin "virga" meaning "rod". Which sounds a bit like viagra which ... oh well never mind.
Thanks heater, that's a load off my mind!
I guess there is a correct name for "\" somewhere. Anyone know?
"octothorpe, exclamation, virgule, bin, virgule, bash"
OK, got it.
There is really no such thing as a "forward slash". It's just a slash. You have to ignore the vertical component of the slash. Since you read left to right, the slash starts on the left and goes to the right, so technically it is forward. In verbal communication I refer to the slash as the "key with the question mark on it".
You description does not help by the way:
"...ignore the vertical component of the slash. Since you read left to right, the slash starts on the left and goes to the right, so technically it is forward."
Thing is they both start on the left and proceed to the right. Except one goes up hill and the other goes down hill. So which do you mean?
On my keyboard the the key with the question mark on it can give me "+" without shift or "\" with AltGr.
For a forward slash, "/" I need shift-7.
See how hopeless it is?
With slashes you have to use the bottom most edge and work your way up.
So these two can watch each other:
@RDL2004,
No good reason at all. It was introduced into ASCII so that they could create the ALGOL language operators OR and AND by using /\ and \/. We have been stuck with that particular piece of nonsense ever since, especially as it became the path separator in MSDOS.
http://en.wikipedia.org/wiki/Backslash
"octothorpe, shriek, virgule, bin, virgule, bash"
At work people use several layouts, so I can't use that. But I just say "slash".. as another poster said, it's just "slash" and "backslash".
-Tor
On my God, you are right. Notice that cream colour sash (slash) over his shoulder. That's exactly a forward slash or virgule.
Well spotted.
