TSL 1401 lineScan sensor
Alejo83
Hello, I looking for help to program de TSL 1401 lineScan.
I have a piece of plastic with the size of a quarter coin(that is the size that I need to Keep). The problem is that the piece of plastic varies(it can go wider or smaller), so basically what I need, if it is possible of course, program the lineScan to detect the edges of the piece of plastic and in the case it varies (wider or smaller) a signal is send to correct the problem.
If this can be done I would appreciate if you guys can provide to me an example of source code with the basic stamp 2 or the basic stamp 2pe motherboard.
Thank you so much and I will be waiting for feedback!
A puller transport the profile from the extruder machine and it is pretty fast but there is an area where the profile is tensioned and it looks like static(the profile doesn't vibrate) that is where I would like to put this lineScan.
I only need that the basic stamp measures and save the right distance between the two edges(having a +- tolerance distance) of the piece of plastic and then the LineScan is going to start comparing the size that is coming out and with the one that is saved in the program.
I don't know if I am correct but it think it doesn't matter the shape of the piece of plastic due that the line scan is just going to measure the distance of the edges(width of the piece of plastic)
If you don't mind you can give me an example with any object, even with the quarter coin. Saving the size of this coin and then comparing it with other coin sizes(a dime for example) and see how the alarm activates! In this way I can have an idea of how this lineScan works and how to program it.
Thank you.
If you can NOT do that, you may have to use a video input and a lot more computational power to measure and verify dimensions.
It sounds as if you have all the items in the same position. And it sounds like using an optical reflective sensor might be a good choice. A CNY70 might be the device to begin with.
The Propeller would offer readings that are more precise as it clocks at a higher speed than any of the BasicStamps. Also, you could have several forms of output.... a simple logic indicating OK, a serial output to a remove computer of an actual number value, and a display as either a LCD or a VGA.
Besides all that, the Propeller is generally a cheaper per unit than the BasicStamp.
http://www.vishay.com/docs/83751/cny70.pdf
I am going to start trying with the reflective sensor as well! Thank you for your advice!
Color may be a problem. It is an IR sensor that uses and LED. You might have to find an optimal non-reflextive color for the background.. a black or a gray. The sensor might just read the relection of the plastic more than the actual color if it is glossy.
It would work on an assembly line situation, but you might have to have a buffer to allow items to wait to be moved past the sensor at a constant rate. It might not have to be a big buffer, but a few items might sit and wait.
