Array of Bytes to a "String" --- HELP!!! — Parallax Forums
zlantzzlantz Posts: 136
edited 2013-09-02 19:04 in Propeller 1
Ok, so this seems like a simple one, but it is giving me the most trouble.
I am recieving via serial a string of bytes "$1000|1500|1250|2000|<CR>" that is servo position data from my pc. I understand that being sent via serial, it is being received one char at a time, so I can create an array with the bytes myarray[0] = $, myarray[1] = 1, myarray[2] = 0 etc, but I cannot use this data to set my servo position. I need a full string in one var ie servopos1 = 1000, servopos2 = 1500, servopos3 = 1250, servopos4 = 2000.
how do I convert myarray[#] into a "string"?
bytemove just ends up with another array[#] of individual letters.
I have tried recoding the gps readNEMA code, as it is a stream of bytes, no luck.
I have a working parsing code, but it needs a full string (myString := "1000|1500|1250|2000|<CR>") to work.
I am stuck with a one byte array string that wont convert into a full sentence and is the only thing stopping my project.
  • Mike GMike G Posts: 2,702
    edited 2013-09-02 09:43
    Welcome to the forum zlantz,
    I'm thinking - you don't want to convert the incoming byte array to a string. It looks like a packet protocol, where the packet starts with a "$" and ends with a <CR>. In between the positions are 2 byte values - most likely- sent as [LSB][MSB].
    For example, the value 1000 decimal is 0x03E8 hexadecimal. When received it looks like [0xE8][0x03].
    But that's just a guess since there's no datasheet or reference accompanying the original post.
  • zlantzzlantz Posts: 136
    edited 2013-09-02 10:29
    I think I have solved my problem just now...
    Con
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    obj
    ser : "fullduplexserial"
    VAR
    PUB Main | mStr, aStr, bStr
    ser.start (31, 30, 0, 115200)
    aStr := string("ABCD")
    repeat
    mStr := 0
    AddString(mStr, aStr, string("ABcd"))
    AddString(mStr, mStr, string("1234"))
    AddString(mStr, mStr, string("$"))
    AddString(mStr, mStr, string("1"))
    AddString(mStr, mStr, string("0"))
    AddString(mStr, mStr, string("|"))
    ser.str(mStr)
    ser.tx(13)
    PRI AddString( dstStrPtr, srcStrPtr1, srcStrPtr2 ) | len
    len := StrSize(srcStrPtr1)
    ByteMove(dstStrPtr, srcStrPtr1, len)
    ByteMove(dstStrPtr += len, srcStrPtr2, StrSize(srcStrPtr2)+1) '+1 for zero termination
    on to parsing the data and testing with servos.
    as for a little more info on how i have it set up:
    PC running program that connects to a Raspberry Pi via tcp/ip, sends servo position data and receives sensor data
    RPi running serial to ip 2 way redirector. Connected via WiFi. (Couldnt get RN-171 working completely (no data flow))
    Prop receives servo data from RPi via serial uart and sends sensor data back
    Prop decodes servo position data & updates position.
    edited 2013-09-02 10:42
    or not, seems to work fine if your typing the string in by hand, but not if i replace string("$") with myArray[0]
    edited 2013-09-02 10:45
    Wrap the SPIN code in code tags to preserve the indentation format.
    [ code ]
    ... Code here
    [ / code]
    Are you sure the transmitted data is ASCII?
    Booyah!
    Con
    obj
    VAR
    byte myArray[6]
    PUB Main | mStr, aStr, bStr, tmp
    aStr := string(" ")
    myArray[0] := string("$")
    myArray[1] := string("1")
    myArray[2] := string("0")
    myArray[3] := string("0")
    myArray[4] := string("1")
    myArray[5] := string("|")
    repeat
    mStr := 0
    AddString(mStr, aStr, myArray[0])
    AddString(mStr, mStr, myArray[1])
    AddString(mStr, mStr, myArray[2])
    AddString(mStr, mStr, myArray[3])
    AddString(mStr, mStr, myArray[4])
    AddString(mStr, mStr, myArray[5])
    ser.str(mStr)
    ser.tx(13)
  • AribaAriba Posts: 2,693
    edited 2013-09-02 11:00
    In your first post you say you will receive a string with the servo positions from the PC. But in your following posts you send the string to the PC. So what will you do really?
    You can replace your code above with one line: ser.str(string("$1000|1500|1250|2000|",13))
    Andy
    edited 2013-09-02 11:52
    PC sends SERVO pos data to MCU,
    MCU sends SENSOR data to PC.
    At the same time.
    the code above was to see if it worked by displaying the rebuilt string on the serial terminal.
    in my code, ser.tx sends to propterm and rpi.tx sends to PC
    btw im still having problems. that code works fine by itself, but when i join it in my big spin it gets all funky.
    depending on how much code is running depends on weather my mcu sends/receives the correct data. one extra ser.tx(13) or anything basic can jam it all up.
    but i have PLENTY of free space (nearly 6,000 longs)
    i guess now i am having problems building the array from each recieved character. it needs to keep it self in order, $ starts <CR> ends data in the middle.
    each time i try something new it garbles all my io data.
    from the looks of it, as of right now, i can see the entire line, but it looks like the matrix on propTerm and it takes a while for one whole line to show up... i know its recieving very fast, i can un comment and recomment some code and it displays everything the pc is sending just fine.
    edited 2013-09-02 12:22
    Okay, here is a possible solution.
    This waits for Servo data and then sends the Sensor data back. Not both at the same time. You can use a second cog if you need it at the same time. I find it much simpler to receie and parse the characters in the same methode, than first receive a string and parse it later.
    CON
    VAR
     long sensorData[4]
     long servoPos[4]
    OBj
     ser : "FullDuplexSerial"
    PUB Main
     repeat
       rxServoData
       txSensorData
    PRI txSensorData             'send 4 sensors decimal
     ser.tx("$")
     ser.dec(sensorData[0])
     ser.tx("|")
     ser.dec(sensorData[1])
     ser.tx("|")
     ser.dec(sensorData[2])
     ser.tx("|")
     ser.dec(sensorData[3])
     ser.tx("|")
     ser.tx(13)
    PRI rxServoData : v | i,ch   'receive and parse servo data
     repeat until ser.rx=="$"
     repeat i from 0 to 3
       v := 0
       repeat
         ch := ser.rx
         case ch
           "0".."9":  v := v*10 + ch-"0"
           other:     quit
       servoPos[i] := v
    this is not tested, but it compiles...
    Andy
    edited 2013-09-02 12:44
    this is in no way complete but this is what i have been using to test different areas, and right now is just returning trash
    Con
      CR = 13
      RPitx  = 14
      RPirx  = 15
    obj
      rpi : "fullduplexserial"
    VAR
      long Servo1Pos, Servo2Pos, Servo3Pos, Servo4Pos, Servo5Pos, Servo6Pos, TxPower   ' RN-171 Storage
      long IR[12], BMP085_Pressure, HIH6130_Temp, HIH6130_Humidity                     ' Sensor Storage
      long Accel[3], Gyro[3], Magnet[3], RSSI                                          ' Sensor Storage
      long Altitude, Valid, Speed, Heading, Date, GPSaltitude, Time                    ' GPS Info
      long Latitude, N_S, Longitude, E_W, Satellites, Hdop, Vdop                       ' GPS Info
      long Data_stack[20], Build_stack[20]
      long cog, cog2, cptr
      byte SVO_buff[23], sPos
      ser.start (31, 30, 0, 115200)                ' To Prop Term
      rpi.start (RPirx, RPitx, 0, 57600)           ' To Raspberry Pi to PC
      cog  := cognew(DoRelay,    @Data_stack)  + 1 ' Data Relay
      cog2 := cognew(BuildArray, @Build_stack) + 1 ' Data Relay
      repeat
        SendDataRPi
        'Tmp := MakeStr
        ser.str(sPos)
        ser.tx(13)
        'if strsize(sPos) > 0
        '  ser.tx(sPos)
        '  ser.tx(13)
    Pri BuildArray                  ' *** Runs in own cog
      repeat
        bytefill(svo_buff , 0, 23)
        repeat until sPos == "$"      ' wait for the $ to insure we are starting with
        cptr := 0
        repeat until sPos == CR       '  continue to collect data until the end of the NMEA sentence
          svo_buff[cptr++] := sPos   '  else save the character
    Pri DoRelay | TmpData, TmpData2  ' *** Runs in own cog    ( Any Delay will cause data to become garbled )
      repeat
        TmpData := rpi.rxCheck       ' Echo RPi Data  *** Had to use .rxCheck as .rx would just hang
        TmpData2 := ser.rxCheck      ' Echo Ser Data
        if TmpData > 0               ' Send RPi to PropTerm
          sPos := TmpData            ' Export Data to Main Loop
        if TmpData2 > 0              ' Send PropTerm to RPi
          rpi.tx(TmpData2)           ' *** Contains Debug Raw Write
    Pri MakeStr | mStr, aStr
      ' Currently Data = "$1500|1000|1250|2000|<CR>"  for servos 1, 2, 3, & 4   but sPos is only 1 char per rx
      aStr := 13    ' *** Must Start with "something"
      mStr := 0     ' Reset myString
      ' 22 chars including CR
      AddString(mStr, aStr, SVO_buff[0])     ' Starts with <CR>
      AddString(mStr, mStr, SVO_buff[1])     ' $
      AddString(mStr, mStr, SVO_buff[2])
      AddString(mStr, mStr, SVO_buff[3])
      AddString(mStr, mStr, SVO_buff[4])
      AddString(mStr, mStr, SVO_buff[5])
      AddString(mStr, mStr, SVO_buff[6])     ' |
      AddString(mStr, mStr, SVO_buff[7])
      AddString(mStr, mStr, SVO_buff[8])
      AddString(mStr, mStr, SVO_buff[9])
      AddString(mStr, mStr, SVO_buff[10])
      AddString(mStr, mStr, SVO_buff[11])    ' |
      AddString(mStr, mStr, SVO_buff[12])
      AddString(mStr, mStr, SVO_buff[13])
      AddString(mStr, mStr, SVO_buff[14])
      AddString(mStr, mStr, SVO_buff[15])
      AddString(mStr, mStr, SVO_buff[16])    ' |
      AddString(mStr, mStr, SVO_buff[17])
      AddString(mStr, mStr, SVO_buff[18])
      AddString(mStr, mStr, SVO_buff[19])
      AddString(mStr, mStr, SVO_buff[20])
      AddString(mStr, mStr, SVO_buff[21])    ' |
      AddString(mStr, mStr, SVO_buff[22])    ' <CR>     *** Might get removed
      return mStr
    Pri AddString( dstStrPtr, srcStrPtr1, srcStrPtr2 ) | len
    Pri SendDataRPi                    ' Send Data to Base Station (Wifi Out)
        ' $GPRMC,081836,A,3751.6565,S,14507.3654,E,000.0,360.0,130998,011.3,E*62
        ' $GPGGA,170834,4124.8963,N,08151.6838,W,1,05,1.5,280.2,M,-34.0,M,,,*75
        ' $PGRMZ,453,f,2*18
        rpi.str(string("$GPS"))    ' GPS
        rpi.str(string(","))
        rpi.dec(0)
        'rpi.dec(GPS.Altitude)
        'rpi.dec(GPS.Valid)
        rpi.dec(0)
        'rpi.dec(GPS.Speed)
        rpi.dec(0)
        'rpi.dec(GPS.Heading)
        rpi.dec(0)
        'rpi.dec(GPS.Date)
        rpi.dec(0)
        'rpi.dec(GPS.GPSaltitude)
        rpi.dec(0)
        'rpi.dec(GPS.Time)
        rpi.dec(0)
        'rpi.dec(GPS.Latitude)
        rpi.dec(0)
        'rpi.dec(GPS.N_S)
        rpi.dec(0)
        'rpi.dec(GPS.Longitude)
        rpi.dec(0)
        'rpi.dec(GPS.E_W)
        rpi.dec(0)
        'rpi.dec(GPS.Satellites)
        rpi.dec(0)
        'rpi.dec(GPS.Hdop)
        rpi.dec(0)
    '    rpi.str(string(","))
    '    rpi.dec(GPS.Vdop)
    '    rpi.tx(13)
    edited 2013-09-02 12:52
    Ok u did it! had to swap a few things around but this is showing correct data from my pc now:
    CON
    VAR
     long sensorData[4]
     long servoPos[4]
    OBj
    PUB Main
     rpi.start (15, 14, 0, 57600)           ' To Raspberry Pi to PC
     repeat
       rxServoData
       ShowServoData
    PRI ShowServoData  | i           'send 4 sensors decimal
      ser.tx(0)
        ser.str(string("Servo "))
        ser.dec(i)
        ser.str(string(" Pos: "))
        ser.dec(servoPos[i])
        ser.tx(13)
     repeat until rpi.rx=="$"
       v := 0
       repeat
         ch := rpi.rx
         case ch
           other:     quit
       servoPos[i] := v
  • JonnyMacJonnyMac Posts: 9,401
    edited 2013-09-02 12:59
    As a matter of curiosity, what PC program are you using to send this data? (I do a lot of work with animatronics)
    edited 2013-09-02 13:02
    OMFG IT WORKS! HAHA! on to getting this thing hooked up to my helicopter!
    Thank you soo much!
    Zack
    but exactly how does that handle the parsing?? if i were to change my chars around i would have no clue were to start. (notibly i probibly wont, but would still like to know)
    edited 2013-09-02 13:03
    JonnyMac - i wrote my own vb6 progrm to handle it
    edited 2013-09-02 13:12
    Got it.
    You may want to add a bit of flexibility to your receive and parse routine -- right now it's locked into a specific array and number of servos. Simple changes let you point that code to another/different array, and work with any number of servos.
    pub rx_servos(p_dest) | c, idx, value
    '' Receive and parse servo positions
    '' -- p_dest is address of servo positions array (words)
      repeat
        c := serial.rx
        if (c == "$")
          quit
      idx := 0
      repeat
        value := 0
        repeat
          c := serial.rx
          case c
            CR:
              return
            "0".."9":
              value := (value * 10) + (c - "0")
            other:
              word[p_dest][idx++] := value
              quit
    edited 2013-09-02 13:20
    zlantz wrote: »
    Thank you soo much!
    Zack
    Cool that it works (no clue what the F in OMFG could mean ;-)
    How the parsing works:
    First it waits until a "$" is received.
    Then it receives every numeric character and "shifts" it in as the lowest digit of the decimal number.
    If a not numerical character is received it must be the ending "|" and the decimal value is stored to the ServoData array.
    This is repeated 4 times.
    The CR is not tested (it is not necessary for the data, but it is useful if you show it on the Terminal).
    Andy
    edited 2013-09-02 17:05
    so if i wanted to add some extra data other than servo positions, how would i be able to include it?
    Any way you want! -- you wrote the PC program that's sending values.
    One thought is to use a different header character to send different groups of values. Of course, you'd have to modify the parser routine as the header character would now be used to determine the destination of values.
