Gaffers tape electrical resista
Of course, vinyl tape is the recommendation for taping stuff electrical. But I find it leaves a sticky residue, and when it gets warm, sometimes comes off too easily. I read that one should NOT use DUCK tape. But what about studio/stage gaffers tape? I've searched for its electrical resistance properties, but find information only on vinyl or duck tapes. Gaffers tape is nice. It's cloth and tears easily in each direction. It doesn't seem to come off as easily as vinyl tape and doesn't leave residue. I can tear small 1/2" by 1/2 square pieces by hand.without scissors or knife.
Now, am using to to cover strew terminals on my projects, in case a wire comes loose, or someone sticks their fingers inside (which they shouldn't be doing.) I do not go from one 120v AC terminal to the next in a single piece, as I'm not sure what the electrical resistance of either the cloth or the adhesive is. Gaffers tape is much easier to work with, But, I can find no critical data on it.
Henry
Henry
Gaffer does have a tendency to come unstuck after a while especially if it is kept warm for prolonged periods. With higher heating it the adhesive tends to bake on but the cloth disintegrates. Of course some brands are better than others.
As for it's resistance properties ... ???
True, but what about this?
That is a brand of "duct" tape that plays on the fact that people mis-pronounce it.
I have lots of gaffers tape. Got several rolls handed to me for free from a movie set. Vinyl tape, and maybe what I have is very cheap stuff, leave a considerable amount of black residue. Alcohol doesn't seem to clean it off, and I haven't tried other solvents yet.
Now, when you talk about HV (high voltage) technically isn't that over 1000 volts? Here's another case where there is confusion about terminology. No, I would not risk gaffers tape, or even electrical vinyl tape on something 1000v or higher. But, are you talking 120VAC?
H.
It is 1.65mm thick
http://www.homedepot.com/p/Scotch-1-in-x-10-ft-2228-Rubber-Mastic-Electrical-Tape-50727-BA-5/202195402
Well at $33 a roll (1/2 inch, 2 mil) its a little out of my poverty level budget. But if you want to send me a roll, I accept. But it would be cool to have a roll of "space tape." as that seems to be one of its advertised uses.
I know that others can not understand $10 being a budget breaker. I just spent $10 on ordering the parts for 3 circuits that I want to build, and I had to think long and hard if I could afford it, before hitting the "complete your order" button. Yes, I'm a crazed tinkerer. I'm also a writer because it's cheap. It's a great feeling to sell a story, but the 6 short stories I have sold haven't provided much boost to my income. Still trying to sell the 10 other short stories I've finished. Give me $100K and I'll make a great movie. But no one has done that yet. Or even $10K, or even $1K. There are actually a lot of things I can do, though making money doesn't seem one of them.
I agree that it is a little expensive for 10 feet but if saves you from frying an expensive propeller board or sensor it could be money well spent.
The point I want to make is, you should not cut corners with improper insulation. Use what is designed for the job and do not try to make due with a substitute.
henrytj: Did you ever consider combining your passions? Write articles for ROBOT or SERVO magazines about your crazed tinkerings. I have written for both and enjoyed getting paid for documenting my ramblings. A few hundred dollars per article won't make you rich, but you will certainly be able to splurge every now and then for some "must have" doohickies.
Only $9 here.
Gaff tape here is 15-20 bucks a roll !
I have used 'electrical tape', but the stuff will become unstuck when there is heat or solvents (like automotive oil and gasoline). Tape is just about the worse choice. At times, I use a dollip of epoxy. Or I coat the connection in silicon and then use shrink wrap.
Out of curiosity, I've emailed 3M for electrical specifications ("Cloth Gaffers Tape 6910").
I'll report back should they choose to answer.
PM sent.
So, anyway, using the meter, I set it to AC volts, and put one probe against a AC contact, and the other probe (will it's actually just a soldered length of wire as the actual probe tip came off years ago.) Anyway, it measured about 10v-12v potential through the gaffers tape. I made sure lay the probe sideways against the single layer of tape on a terminal, so the probe was not poking into/through the tape. So, everyone is right. Gaffers tape is not a insulator. I have yet to find one of my rolls of vinyl tape (that I know I also have somewhere) to check for comparison.
Now, please understand. I am not using the tape to wrap wires. But to put a small 1/2"x1/2" square of tape overtop the SSR screwdown terminals. I am building my boxes with 4-gang plastic junction boxes from a hardware store. I can only find 3-gang cover plates that cover most of the box. Part is left open and it is where I have the SSR attached. So I am usind the tape to cover the AC screw down terminals so that someone is not tempted to reach into the box, where the terminals are visible, and touch them. The tape does not go between the terminals. So it's not a situation where heat shrink tubing will work.
Well, I finally received a reply from 3M asking about the voltage breakdown/isolation spec:
"We have never done any electrical tests on this tape." Suppressed info or claimed no knowledge of = "Get out of jail free" card.
I'm as suspicious of this as when I see "Be the first to write a review" or "no reviews yet" of an item that's NOT new.
As I said before I think that PVC tape is the number 1 option as it's impervious to damp
