XBee setup for long distance USB devices
Hello all.
I am trying to do a long distance USB cable extender. I am thinking of using a CON-USBBEE board plus one X-Bee in each end, howver I have no experience with XBee.
The idea, would be that the data from one side of the usb cable would go to the CON-USBBEE, which would send it to the XBee, the Xbee would then send to another xbee, which would send the signal to a second CON-USBBEE which would send the data to the target computer.
Does anyone know if this is possible? Would anyone point me in the right direction?
Any help would be greatly appreciated.
Thank you for your time.
Could you please clarify what you mean when you say that it can work for only a single serial port? Does this means that it can be used in only one device? Or that once I instert the Xbee in a physical port it "binds" to that port, and needs to be reconfigured before being use din another PC or another port?
Either of those is fine by me, I intend to use it in just one notebook and one EVO4
Sorry if this is a dumb question but I am new to this whole wireless thing.
Notebook
CON-USBBEE
xBee --^^^-- xBee
CON-USBBEE
EVO4
What you need is:
Notebook
CON-USBBEE
xBee --^^^-- xBee
USB-Host-Bridge
EVO4
It's not at all clear whether the EVO4 software on the notebook side will allow this sort of connection and it's not at all clear that the EVO4 will work with any USB host that's not a PC running its software. Theoretically, you might be able to use something like Parallax's Memory Stick Datalogger to act as a USB-Host-Bridge, but it's not at all clear that this would work. It's certainly not a beginner's project and a lot depends on what documentation is available on the EVO4's USB interface details.
There used to be a general purpose wireless USB extender on the market that would do what you want, but I don't think it's on the market anymore (see here). You might be able to find one or something similar on the internet. I don't know why they're no longer available.
