General Purpose Sensor Activated Controller with Four Relays and LED Readout
Attached are five files describing a Basic Stamp 2 general purpose relay controller with LED display that may be activated by an analog or digital sensor.
I suggest that you read the "Controller Information" PDF first and follow along with the two schematics, also in PDF. In addition, there are also two code files that demonstrate the operation of the controller. One file demos the LM34 analog temperature sensor and the other file the DS1620 digital temperature sensor.
For those of you with strong stomachs there is also a jpg showing the breadboard.
I would be interested in your comments about the code and especially any modifications you might suggest
Marty
Marty
