SimpleIDE Library Bug — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2013-09-05 14:59 in Propeller 1
Hi all.
We have found a serious bug with library archiving. The bug exists in SimpleIDE versions having Simple Libraries up to 0-9-40-x.
Please do not open and zip any library projects in the "Documents\SimpleIDE\Learn\Simple Libraries" folder.
Zipping library projects will crash SimpleIDE and and leave a folder in the library that can't be removed from your system.
I can't apologize enough to anyone that may have already encountered this problem.
I'm having to deal with the issue too. That is, I have some folders on my system that I can not delete.
Sincerely,
--Steve
  • SRLMSRLM Posts: 5,045
    edited 2013-08-21 17:57
    What operating systems does this apply to?
  • dgatelydgately Posts: 1,641
    edited 2013-08-21 18:02
    Ouch!
    Let me know when you have something to test on Mac OS X. I'll add that to my standard SimpleIDE test cases...
    dgately
    edited 2013-08-21 18:10
    Happens to all of us at some time Steve. Don't stress too much. Hopefully one of the tools out there will work for you.
    What format is your HDD - is it FAT32 ???
  • jazzedjazzed Posts: 11,803
    edited 2013-08-21 18:33
    This most likely applies to all O/S, but I've only had the issue show up on Windows. That's where I've been making some new libraries. Thankfully the problem folder can be moved at least.
    I'm using Window's 7 NTFS.
    Thanks for your support.
    edited 2013-08-21 18:43
    Interestingly, I'm not able to reproduce this issue with version 0-9-29 on my Windows 8 VM. I'll defer to old man Murphy on this though.
  • tdlivingstdlivings Posts: 437
    edited 2013-08-21 19:55
    Steve
    This may not be the issue you are seeing but I will mention it as food for thought just in case.
    When I was trying to install 0-9-40 I went to rename my present SimpleIDE folder and the OS
    said no way another app has that folder open. However I did not see any app open .
    I was able to use WinZip to make a backup of the folder so I said ok I will delete it and again the
    OS said no way.
    The answer was that SnagIt my screen capture app which has a piece of itself loaded always to watch
    for print Screen was the app that had attached itself to the folder because I had made several captures
    and stored the images somewhere in the SimpleIDE folder structure. Because the image files were
    still in the SnagIt Image Editor list, SnagIT was protecting the path to those images.
    Closing SnagIt completely and again I could rename the folder or do anything I wanted to it.
    Windows 7 Pro.
    Maybe something has a hold of the folders on your pc and it is not obvious that it does.
    Tom
    edited 2013-08-21 20:27
    Jazzed,
    I'm actually crashing SimpleIDE on MAC OS X when I try to ZIP a library project. I know I had tested this previously (probably with 9-29) and it worked.
    Steps:
    1. Copy/Duplicate any of the library projects the "Documents\SimpleIDE\Learn\Simple Libraries" folder
    2. Open the library's project in SimpleIDE vers: 0-9-40
    3. Compile the project with Memory Model: CMM Main RAM, Optimization: -Os Size (it succeeds)
    4. Attempt to ZIP the project
    Result (a crash in: Thread 0:
    0 com.Parallax.SimpleIDE 0x0000000100035177 MainSpinWindow::flattenDstProject(QString, QString) + 635):
    Process:         SimpleIDE [19195]
    Path:            /Applications/SimpleIDE.app/Contents/MacOS/SimpleIDE
    Identifier:      com.Parallax.SimpleIDE
    Version:         ???
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [265]
    User ID:         502
    Date/Time:       2013-08-21 20:23:37.931 -0700
    OS Version:      Mac OS X 10.8.4 (12E55)
    Report Version:  10
    Interval Since Last Report:          1569689 sec
    Crashes Since Last Report:           2
    Per-App Crashes Since Last Report:   4
    Anonymous UUID:                      6D477AAA-036B-F73F-C24A-430B8CB182C1
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
    VM Regions Near 0:
        __TEXT                 0000000100000000-000000010028e000 [ 2616K] r-x/rwx SM=COW  /Applications/SimpleIDE.app/Contents/MacOS/SimpleIDE
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    [COLOR=#ff0000]0   com.Parallax.SimpleIDE            0x0000000100035177 MainSpinWindow::flattenDstProject(QString, QString) + 635
    [/COLOR]1   com.Parallax.SimpleIDE            0x000000010003b2d4 MainSpinWindow::zipCproject(QStringList, QString, QString, QString, QString, QString) + 12070
    2   com.Parallax.SimpleIDE            0x0000000100043272 MainSpinWindow::zipProject() + 6088
    3   com.Parallax.SimpleIDE            0x0000000100108ef6 MainSpinWindow::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 2582
    4   QtCore                            0x00000001010381fe QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 1566
    5   QtGui                             0x00000001009fd8d1 QAbstractButton::clicked(bool) + 49
    6   QtGui                             0x0000000100722f80 QAbstractButton::mousePressEvent(QMouseEvent*) + 208
    7   QtGui                             0x00000001007241ba QAbstractButton::keyPressEvent(QKeyEvent*) + 778
    8   QtGui                             0x0000000100724411 QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 113
    9   QtGui                             0x00000001007f2112 QToolButton::mouseReleaseEvent(QMouseEvent*) + 18
    10  QtGui                             0x00000001003ddf71 QWidget::event(QEvent*) + 2369
    11  QtGui                             0x00000001007232b8 QAbstractButton::event(QEvent*) + 40
    12  QtGui                             0x00000001007f416f QToolButton::event(QEvent*) + 63
    13  QtGui                             0x0000000100382fad QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
    14  QtGui                             0x000000010038a510 QApplication::notify(QObject*, QEvent*) + 2384
    15  QtCore                            0x000000010102075c QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
    16  QtGui                             0x000000010038828d QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 333
    17  QtGui                             0x000000010033a7e5 QMacCocoaAutoReleasePool::~QMacCocoaAutoReleasePool() + 18917
    18  com.apple.AppKit                  0x00007fff8421f5d6 -[NSWindow sendEvent:] + 7053
    19  QtGui                             0x000000010032fb67 QMacInputContext::reset() + 24215
    20  com.apple.AppKit                  0x00007fff8421b644 -[NSApplication sendEvent:] + 5761
    21  QtGui                             0x0000000100334974 QMacInputContext::reset() + 44196
    22  com.apple.AppKit                  0x00007fff8413121a -[NSApplication run] + 636
    23  QtGui                             0x000000010033f750 QDesktopWidget::resizeEvent(QResizeEvent*) + 13024
    24  QtCore                            0x000000010101f664 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
    25  QtCore                            0x000000010101fa14 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 324
    26  QtCore                            0x000000010102290c QCoreApplication::exec() + 188
    27  com.Parallax.SimpleIDE            0x0000000100004ac9 main + 4761
    28  com.Parallax.SimpleIDE            0x0000000100003804 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib            0x00007fff86bfed16 kevent + 10
    1   libdispatch.dylib                 0x00007fff8b291dea _dispatch_mgr_invoke + 883
    2   libdispatch.dylib                 0x00007fff8b2919ee _dispatch_mgr_thread + 54
    Thread 2:
    0   libsystem_kernel.dylib            0x00007fff86bfe0fa __psynch_cvwait + 10
    1   libsystem_c.dylib                 0x00007fff8d9fafe9 _pthread_cond_wait + 869
    2   QtCore                            0x0000000100f0da50 QWaitCondition::wait(QMutex*, unsigned long) + 304
    3   QtGui                             0x0000000100864c33 QFileSystemModel::sort(int, Qt::SortOrder) + 30819
    4   QtCore                            0x0000000100f0d5aa QThread::terminate() + 762
    5   libsystem_c.dylib                 0x00007fff8d9f67a2 _pthread_start + 327
    6   libsystem_c.dylib                 0x00007fff8d9e31e1 thread_start + 13
    Thread 3:
    1   QtCore                            0x0000000101001fa9 QProcessEnvironment::systemEnvironment() + 53049
    2   QtCore                            0x0000000100f0d5aa QThread::terminate() + 762
    3   libsystem_c.dylib                 0x00007fff8d9f67a2 _pthread_start + 327
    4   libsystem_c.dylib                 0x00007fff8d9e31e1 thread_start + 13
    Thread 4:
    0   libsystem_kernel.dylib            0x00007fff86bfe322 __select + 10
    1   QtCore                            0x0000000100ff44e0 QFSFileEngine::fileName(QAbstractFileEngine::FileName) const + 19584
    Thread 5:: com.apple.CFSocket.private
    1   com.apple.CoreFoundation          0x00007fff8e830f46 __CFSocketManager + 1302
    2   libsystem_c.dylib                 0x00007fff8d9f67a2 _pthread_start + 327
    3   libsystem_c.dylib                 0x00007fff8d9e31e1 thread_start + 13
    Thread 6:
    0   libsystem_kernel.dylib            0x00007fff86bfe6d6 __workq_kernreturn + 10
    1   libsystem_c.dylib                 0x00007fff8d9f8f4c _pthread_workq_return + 25
    2   libsystem_c.dylib                 0x00007fff8d9f8d13 _pthread_wqthread + 412
    3   libsystem_c.dylib                 0x00007fff8d9e31d1 start_wqthread + 13
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x0000000000000000  rcx: 0x00000001011b7dd8  rdx: 0x00000000ffffff01
      rdi: 0x00007fff5fbfcd30  rsi: 0x00007fff5fbfcc80  rbp: 0x00007fff5fbfce40  rsp: 0x00007fff5fbfccb0
       r8: 0x000000010121be00   r9: 0x0000000000000004  r10: 0x0210862301010003  r11: 0x0000000000000010
      r12: 0x00007fff5fbfcd88  r13: 0x0000000103ce6f50  r14: 0x00007fff5fbfcd10  r15: 0x00007fff5fbfcd18
      rip: 0x0000000100035177  rfl: 0x0000000000010206  cr2: 0x0000000000000000
    Logical CPU: 2
    Binary Images:
           0x100000000 -        0x10028dff7 +com.Parallax.SimpleIDE (???) <857E12BE-2645-3966-9F40-584DA962CCF8> /Applications/SimpleIDE.app/Contents/MacOS/SimpleIDE
           0x1002bd000 -        0x1002f0fff +libquazip.1.dylib (1) <23B7D852-5982-3C63-A53A-3009D47656A8> /Applications/SimpleIDE.app/Contents/Frameworks/libquazip.1.dylib
           0x1002fe000 -        0x100d09fe7 +QtGui (4.8) <D5588EC0-CB69-31E3-B1AA-4772B88EAD96> /Applications/SimpleIDE.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
           0x100ee6000 -        0x1011acfff +QtCore (4.8) <9726D48A-4CC7-0E50-2E62-2568E27A8546> /Applications/SimpleIDE.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
           0x1012ee000 -        0x1012f4ff7 +libqgif.dylib (0) <7DED8794-5E9E-8F39-B352-BD4A7EF2B68C> /Applications/SimpleIDE.app/Contents/PlugIns/imageformats/libqgif.dylib
           0x1015e3000 -        0x1015e9ff7 +libqico.dylib (0) <49099C6F-BD77-21BE-DAE0-4343189E401E> /Applications/SimpleIDE.app/Contents/PlugIns/imageformats/libqico.dylib
           0x102b05000 -        0x102b05ffb +cl_kernels (???) <B6F3FCD8-9E14-4E2A-A121-0A5CC6344248> cl_kernels
           0x102f83000 -        0x102fbeff7 +libqjpeg.dylib (0) <A08AEE00-0C93-A2DD-3E4F-2AA28E0F2799> /Applications/SimpleIDE.app/Contents/PlugIns/imageformats/libqjpeg.dylib
           0x103e00000 -        0x103eb9ff7  ColorSyncDeprecated.dylib (400) <7CE58F6E-D2C8-39FB-8EE0-28CC6EC6D04F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
           0x103f01000 -        0x103f55fef +libqmng.dylib (0) <53D1DBC6-5F9C-7470-F35C-991DCD59B315> /Applications/SimpleIDE.app/Contents/PlugIns/imageformats/libqmng.dylib
           0x103f5d000 -        0x103fb2ff7 +libqtiff.dylib (0) <373A97D2-431F-60E8-A708-A1282F552EA9> /Applications/SimpleIDE.app/Contents/PlugIns/imageformats/libqtiff.dylib
           0x107202000 -        0x107202ff9 +cl_kernels (???) <20F73265-F328-4BC6-8F47-37B4DE260B0E> cl_kernels
           0x10720e000 -        0x107217fe7  libcldcpuengine.dylib (2.2.16) <DB9678F6-7D50-384A-A961-6109B61D1607> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
           0x10758d000 -        0x10758effa +cl_kernels (???) <7621915A-5479-4722-8FDA-2F97C002F714> cl_kernels
           0x107ffa000 -        0x107ffbffb +cl_kernels (???) <E5718D8B-96A2-458B-93E1-4C14491A75EF> cl_kernels
           0x10b7fb000 -        0x10b7fcffb +cl_kernels (???) <89FEEEA7-40B7-41BD-876B-3D6C18EB5545> cl_kernels
           0x10cc80000 -        0x10cd1aff7  unorm8_bgra.dylib (2.2.16) <5D62BED8-DF5D-3C51-94B4-57368FF10DDB> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
           0x10cfc8000 -        0x10cfecff7  com.apple.security.csparser (3.0 - 55179.13) <B85553DE-708C-3C20-93D5-70DC80068CE3> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
           0x10ec8f000 -        0x10ed28ff7  unorm8_argb.dylib (2.2.16) <AC4A19D0-44A5-34CB-9248-20996ACA6B06> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_argb.dylib
        0x7fff6e948000 -     0x7fff6e97c93f  dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
        0x7fff83b01000 -     0x7fff83b01fff  com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff83b02000 -     0x7fff83b03fff  libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
        0x7fff83b2f000 -     0x7fff83b41ff7  libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
        0x7fff83b42000 -     0x7fff83c3ffff  libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
        0x7fff83c40000 -     0x7fff83d60fff  com.apple.desktopservices (1.7.4 - 1.7.4) <ED3DA8C0-160F-3CDC-B537-BF2E766AB7C1> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff83d61000 -     0x7fff83f96ff7  com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff83fe1000 -     0x7fff83fe4fff  com.apple.AppleSystemInfo (2.0 - 2) <BC221376-361F-3F85-B284-DC251D3BB442> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff83fe5000 -     0x7fff84c12fff  com.apple.AppKit (6.8 - 1187.39) <199962F0-B06B-3666-8FD5-5C90374BA16A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff84c13000 -     0x7fff84c94fff  com.apple.Metadata (10.7.0 - 707.11) <2DD25313-420D-351A-90F1-300E95C970CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff84cff000 -     0x7fff84e85fff  libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff84e86000 -     0x7fff84e95ff7  libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
        0x7fff84e96000 -     0x7fff84ea1ff7  com.apple.DisplayServicesFW (2.7.2 - 357) <EC87A00D-FE9C-3CFE-A98C-063C3D23085A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
        0x7fff85118000 -     0x7fff8513aff7  com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff8513b000 -     0x7fff8523dfff  libcrypto.0.9.8.dylib (47.1) <72AA650B-0453-3BB4-BA03-824627BB199C> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff8523e000 -     0x7fff8523efff  libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
        0x7fff8523f000 -     0x7fff85295fff  com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff852d5000 -     0x7fff852d6fff  libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff852d7000 -     0x7fff852e8ff7  libsasl2.2.dylib (166) <649CAE0E-8FFE-3C60-A849-BE6300E4B726> /usr/lib/libsasl2.2.dylib
        0x7fff852e9000 -     0x7fff853daff7  com.apple.DiskImagesFramework (10.8.3 - 345) <F9FAEAF0-B9A5-34DF-94B7-926FB03AD5F6> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff853db000 -     0x7fff853effff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff853f0000 -     0x7fff85421ff7  com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff85455000 -     0x7fff85719fff  com.apple.AddressBook.framework (7.1 - 1170) <A850809B-B087-3366-9FA0-1518C20831D3> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
        0x7fff8571a000 -     0x7fff8571afff  com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff8571b000 -     0x7fff857edff7  com.apple.CoreText (260.0 - 275.16) <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff85835000 -     0x7fff85863ff7  libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
        0x7fff85a1a000 -     0x7fff85a66ff7  libauto.dylib (185.4) <AD5A4CE7-CB53-313C-9FAE-673303CC2D35> /usr/lib/libauto.dylib
        0x7fff85a79000 -     0x7fff85aa1fff  libJPEG.dylib (850) <DC750E1E-BD07-339B-A4A6-D86BFE969F68> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff85aa2000 -     0x7fff85af1ff7  libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
        0x7fff85bc1000 -     0x7fff85c1dff7  com.apple.Symbolication (1.3 - 93) <F2C7E0B6-B241-3020-B30A-0636D0FA3378> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
        0x7fff85c1e000 -     0x7fff85c1efff  com.apple.quartzframework (1.5 - 1.5) <6403C982-0D45-37EE-A0F0-0EF8BCFEF440> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff85c1f000 -     0x7fff85c55fff  libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
        0x7fff85ca2000 -     0x7fff8602dff7  com.apple.FinderKit (1.1.3 - 1.1.3) <7956AB84-AB7A-3B00-A543-76E5CD708881> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
        0x7fff8602e000 -     0x7fff8644bfff  FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
        0x7fff8644c000 -     0x7fff8644cfff  com.apple.Carbon (154 - 155) <372716D2-6FA1-3611-8501-3DD1D4A6E8C8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff8644d000 -     0x7fff866baff7  com.apple.RawCamera.bundle (4.07 - 696) <CCB97D78-309C-3CD9-B499-81192069A333> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff866be000 -     0x7fff866c9fff  com.apple.CommonAuth (3.0 - 2.0) <7A953C1F-8B18-3E46-9BEA-26D9B5B7745D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff866cc000 -     0x7fff869fcfff  com.apple.HIToolbox (2.0 - 626.1) <656D08C2-9068-3532-ABDD-32EC5057CCB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff869fd000 -     0x7fff86a34ff7  libssl.0.9.8.dylib (47.1) <B7C438BB-79FF-37B3-B8FB-253E5135CBB4> /usr/lib/libssl.0.9.8.dylib
        0x7fff86a43000 -     0x7fff86a47ff7  com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff86a48000 -     0x7fff86a76fff  com.apple.shortcut (2.2 - 2.2) <C573DB65-37FB-3DDC-AB19-525094346D9B> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
        0x7fff86a77000 -     0x7fff86ab1fff  com.apple.framework.internetaccounts (2.1 - 210) <546769AA-C561-3C17-8E8E-4E65A700E2F1> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
        0x7fff86ab2000 -     0x7fff86ac5ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff86ac6000 -     0x7fff86b79ff7  com.apple.PDFKit (2.8.4 - 2.8.4) <BD6E8774-1C8B-3CD1-B5FA-7352B2173068> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
        0x7fff86b91000 -     0x7fff86bebfff  com.apple.print.framework.PrintCore (8.3 - 387.2) <5BA0CBED-4D80-386A-9646-F835C9805B71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff86bec000 -     0x7fff86c07ff7  libsystem_kernel.dylib (2050.24.15) <A9F97289-7985-31D6-AF89-151830684461> /usr/lib/system/libsystem_kernel.dylib
        0x7fff86c08000 -     0x7fff86c42ff7  com.apple.GSS (3.0 - 2.0) <970CAE00-1437-3F4E-B677-0FDB3714C08C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff86c43000 -     0x7fff86c51fff  libcommonCrypto.dylib (60027) <BAAFE0C9-BB86-3CA7-88C0-E3CBA98DA06F> /usr/lib/system/libcommonCrypto.dylib
        0x7fff86c52000 -     0x7fff86c72fff  libPng.dylib (850) <203C43BF-FAD3-3CCB-81D5-F2770E36338B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff875b9000 -     0x7fff875d0fff  com.apple.CFOpenDirectory (10.8 - 151.10) <FFBBA538-00B5-334E-BA5B-C8AD6CDCDA14> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff875d1000 -     0x7fff875f8ff7  com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff875f9000 -     0x7fff8764eff7  libTIFF.dylib (850) <EDAF0D99-70AF-3B3F-9EFA-9463C91D0E3C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff8860f000 -     0x7fff88626fff  com.apple.GenerationalStorage (1.1 - 132.3) <FD4A84B3-13A8-3C60-A59E-25A361447A17> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff88627000 -     0x7fff88686fff  com.apple.AE (645.6 - 645.6) <44F403C1-660A-3543-AB9C-3902E02F936F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff88712000 -     0x7fff88756fff  libcups.2.dylib (327.6) <9C01D012-6F4C-3B69-B614-1B408B0ED4E3> /usr/lib/libcups.2.dylib
        0x7fff887a8000 -     0x7fff887abfff  libRadiance.dylib (850) <62E3F7FB-03E3-3937-A857-AF57A75EAF09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff887ac000 -     0x7fff88a5bfff  com.apple.imageKit (2.2 - 673) <5F0504DA-7CE9-3D97-B2B5-3C5839AEBF1F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
        0x7fff88a77000 -     0x7fff88a7cfff  libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
        0x7fff88a7d000 -     0x7fff88b17fff  libvMisc.dylib (380.6) <714336EA-1C0E-3735-B31C-19DFDAAF6221> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff88b18000 -     0x7fff892bffff  com.apple.CoreAUC (6.16.13 - 6.16.13) <8CBFBC9C-0773-3DEB-AF99-989008CB2B36> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff892c0000 -     0x7fff892c0fff  libOpenScriptingUtil.dylib (148.3) <F8681222-0969-3B10-8BCE-C55A4B9C520C> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff892c1000 -     0x7fff89300ff7  com.apple.QD (3.42.1 - 285.1) <77A20C25-EBB5-341C-A05C-5D458B97AD5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff89301000 -     0x7fff8931cff7  com.apple.frameworks.preferencepanes (15.1 - 15.1) <8A3CDC5B-9FA5-32EB-A066-F19874193B92> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
        0x7fff8931d000 -     0x7fff8938bff7  com.apple.framework.IOKit (2.0.1 - 755.24.1) <04BFB138-8AF4-310A-8E8C-045D8A239654> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff8938c000 -     0x7fff893d7fff  com.apple.framework.CoreWLAN (3.3 - 330.15) <047FA8CB-7447-3171-9518-6C88DA71F20E> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff893d8000 -     0x7fff893e1ff7  com.apple.CommerceCore (1.0 - 26.1) <40A129A8-4E5D-3C7A-B299-8CB203C4C65D> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff893e2000 -     0x7fff894fbfff  com.apple.ImageIO.framework (3.2.1 - 850) <C3FFCEEB-AA0C-314B-9E94-7005EE48A403> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff89505000 -     0x7fff89507fff  com.apple.securityhi (4.0 - 55002) <34E45C60-DC7E-3FCC-A1ED-EBF48B77C559> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff89508000 -     0x7fff89561ff7  com.apple.ImageCaptureCore (5.0.4 - 5.0.4) <84F003C2-5758-3D0A-8644-F3A0BA4F22FC> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
        0x7fff89602000 -     0x7fff89611fff  com.apple.opengl (1.8.9 - 1.8.9) <6FD163A7-16CC-3D1F-B4B5-B0FDC4ADBF79> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff89613000 -     0x7fff8961afff  com.apple.phonenumbers (1.1 - 47) <E6A01FEF-9C6D-3C18-B378-63F4134756E6> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
        0x7fff8961b000 -     0x7fff8963cff7  libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
        0x7fff8964e000 -     0x7fff896b6ff7  libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
        0x7fff896b7000 -     0x7fff896fffff  libcurl.4.dylib (69.2) <EBDBF42D-E4A6-3D05-A76B-2817D79D59E2> /usr/lib/libcurl.4.dylib
        0x7fff89700000 -     0x7fff8976dff7  com.apple.datadetectorscore (4.1 - 269.3) <5775F0DB-87D6-310D-8B03-E2AD729EFB28> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff8976f000 -     0x7fff89771fff  libCVMSPluginSupport.dylib (8.9.2) <EF1192AC-3357-3A0B-BFAF-6594D7737892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff89772000 -     0x7fff8977eff7  com.apple.DirectoryService.Framework (10.8 - 151.10) <DA05EF06-8EBD-3759-B5D3-E6FC86C5D850> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
        0x7fff8977f000 -     0x7fff897dbfff  com.apple.QuickLookFramework (4.0 - 555.5) <8B9EAC35-98F3-3BF0-8B15-3A5FE39F150A> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff897dc000 -     0x7fff89b3bfff  com.apple.Foundation (6.8 - 945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff89b3c000 -     0x7fff89b53fff  libGL.dylib (8.9.2) <B8E5948D-BCF2-3727-B74E-D74B8EDC82D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff89b54000 -     0x7fff89b5fff7  com.apple.aps.framework (3.0 - 3.0) <DEF85257-2D1C-3524-88F8-CF70980726AE> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
        0x7fff8a3ba000 -     0x7fff8a3c7ff7  com.apple.HelpData (2.1.4 - 85) <EE68BDCC-AF2E-34D3-8E4F-87379E3A4D8E> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
        0x7fff8a3c8000 -     0x7fff8a3ccfff  libGIF.dylib (850) <D4525F87-759C-338C-B283-BB8DE815D3D5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff8a3cd000 -     0x7fff8a3f2ff7  libc++abi.dylib (26) <D86169F3-9F31-377A-9AF3-DB17142052E4> /usr/lib/libc++abi.dylib
        0x7fff8a3f3000 -     0x7fff8a4f0ff7  libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
        0x7fff8a4f1000 -     0x7fff8a585ff7  com.apple.CorePDF (2.2 - 2.2) <F17D7D37-4190-38E2-9F43-DD4F87792390> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
        0x7fff8a586000 -     0x7fff8a5e0fff  com.apple.Suggestions (2.0 - 102.1) <05D8D892-9A31-301A-BD24-D8A89B2AC905> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
        0x7fff8a62f000 -     0x7fff8a62ffff  com.apple.AOSMigrate (1.0 - 1) <585B1483-490E-32DD-97DC-B9279E9D3490> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
        0x7fff8a630000 -     0x7fff8a6edff7  com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff8a6ee000 -     0x7fff8a76eff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039-AB25-3E3E-9975-A67DAE66988B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff8a76f000 -     0x7fff8a789fff  com.apple.CoreMediaAuthoring (2.1 - 914) <CFA664F9-D5A7-3281-A12F-3ED8A98FD8C1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
        0x7fff8a78a000 -     0x7fff8a7fafff  com.apple.ISSupport (1.9.8 - 56) <23ED7650-2705-355A-9F11-409A9981AC53> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
        0x7fff8a7fb000 -     0x7fff8a863fff  libvDSP.dylib (380.6) <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff8a86f000 -     0x7fff8a896fff  com.apple.framework.familycontrols (4.1 - 410) <50F5A52C-8FB6-300A-977D-5CFDE4D5796B> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
        0x7fff8a897000 -     0x7fff8a900fff  libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
        0x7fff8a901000 -     0x7fff8ab82fff  com.apple.AOSKit (1.051 - 152.4) <01C09924-2603-3C1E-97F7-9484CBA35BC9> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
        0x7fff8ab85000 -     0x7fff8ab8bfff  libCGXCoreImage.A.dylib (332) <F6300A73-D4C4-3DE6-A1B7-806E627CCF76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
        0x7fff8ab8c000 -     0x7fff8abc2fff  com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff8abc3000 -     0x7fff8abcffff  libCSync.A.dylib (332) <47466CF6-EB5C-3312-9E24-178F4410A92B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
        0x7fff8abd0000 -     0x7fff8abd2ff7  libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
        0x7fff8abd4000 -     0x7fff8abdefff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff8abdf000 -     0x7fff8ac2afff  com.apple.CoreMedia (1.0 - 926.104) <31EAF297-9C42-3D6F-A8A1-CDAB94A26113> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff8ac2b000 -     0x7fff8ac8eff7  com.apple.audio.CoreAudio (4.1.1 - 4.1.1) <9ACD3AED-6C04-3BBB-AB2A-FC253B16D093> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff8ac8f000 -     0x7fff8ae3dfff  com.apple.QuartzCore (1.8 - 304.3) <F450F2DE-2F24-3557-98B6-310E05DAC17F> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8ae3e000 -     0x7fff8ae6cfff  com.apple.CoreServicesInternal (154.3 - 154.3) <F4E118E4-E327-3314-83D7-EA20B1717ED0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff8ae6d000 -     0x7fff8ae73fff  com.apple.DiskArbitration (2.5.2 - 2.5.2) <C713A35A-360E-36CE-AC0A-25C86A3F50CA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff8ae74000 -     0x7fff8af25fff  com.apple.LaunchServices (539.9 - 539.9) <07FC6766-778E-3479-8F28-D2C9917E1DD1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff8af26000 -     0x7fff8b0c1fef  com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff8b1dc000 -     0x7fff8b1e4fff  liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
        0x7fff8b1e5000 -     0x7fff8b220fff  com.apple.LDAPFramework (2.4.28 - 194.5) <7C71C445-2B52-3AC0-97E5-9F2E692C8F5C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff8b221000 -     0x7fff8b225fff  libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
        0x7fff8b226000 -     0x7fff8b22dfff  com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff8b22e000 -     0x7fff8b27dfff  com.apple.framework.CoreWiFi (1.3 - 130.13) <CCF3D8E3-CD1C-36CD-929A-C9972F833F24> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff8b28d000 -     0x7fff8b2a2ff7  libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
        0x7fff8b2a3000 -     0x7fff8b4feff7  com.apple.QuartzComposer (5.1 - 284) <D9CDC9ED-9F03-30F0-80DF-BA189A054AC9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
        0x7fff8b4ff000 -     0x7fff8b93bfef  com.apple.VideoToolbox (1.0 - 926.104) <9231E12F-3D46-3F3D-B24F-6E16127E5909> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff8b93c000 -     0x7fff8b986ff7  libGLU.dylib (8.9.2) <1B5511FF-1064-3004-A245-972CE5687D37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff8b98b000 -     0x7fff8ba80fff  libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
        0x7fff8bac4000 -     0x7fff8bac4fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <6AD48543-0864-3D40-80CE-01F184F24B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff8baf7000 -     0x7fff8bafafff  com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff8bb56000 -     0x7fff8bbe3ff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff8bc8c000 -     0x7fff8bc8dff7  libSystem.B.dylib (169.3) <365477AB-D641-389D-B8F4-A1FAE9657EEE> /usr/lib/libSystem.B.dylib
        0x7fff8bc8e000 -     0x7fff8bc92fff  libCGXType.A.dylib (332) <17C8DD17-B3CB-3633-B252-C368AE51204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
        0x7fff8bc93000 -     0x7fff8bcbdff7  com.apple.CoreVideo (1.8 - 99.4) <E5082966-6D81-3973-A05A-38AA5B85F886> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff8bcea000 -     0x7fff8bceefff  libCoreVMClient.dylib (32.3) <AD8391D9-56DD-3A78-A294-6A30E6ECE1A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff8bcef000 -     0x7fff8bd6dff7  com.apple.securityfoundation (6.0 - 55115.4) <C5461971-E455-31A6-99B8-AF80C4BC26DD> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff8bdde000 -     0x7fff8bf30fff  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <62770C0F-5600-3EF9-A893-8A234663FFF5> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff8bf31000 -     0x7fff8bf36fff  com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff8bf37000 -     0x7fff8bf84fff  com.apple.CoreMediaIO (308.0 - 4155.4) <B563579E-469D-39A1-975C-F4EDD419602E> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
        0x7fff8bfa1000 -     0x7fff8bfacff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff8c00a000 -     0x7fff8c00affd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <EC55FB59-2443-3F08-9142-7BCC93C76E4E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff8c014000 -     0x7fff8c022fff  com.apple.Librarian (1.1 - 1) <5AC28666-7642-395F-A923-C6F8A274BBBD> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
        0x7fff8c02d000 -     0x7fff8c02fff7  com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff8c030000 -     0x7fff8c037fff  libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
        0x7fff8c038000 -     0x7fff8c064ff7  libRIP.A.dylib (332) <D26BC320-B415-3C4D-B57F-D525FC361BB2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff8c065000 -     0x7fff8c265fff  libicucore.A.dylib (491.11.3) <5783D305-04E8-3D17-94F7-1CEAFA975240> /usr/lib/libicucore.A.dylib
        0x7fff8c2df000 -     0x7fff8c3a4ff7  com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff8c3a5000 -     0x7fff8c3e8ff7  com.apple.RemoteViewServices (2.0 - 80.6) <5CFA361D-4853-3ACC-9EFC-A2AC1F43BA4B> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff8c3e9000 -     0x7fff8c3effff  libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
        0x7fff8c3f0000 -     0x7fff8c3f6ff7  libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
        0x7fff8c732000 -     0x7fff8c781ff7  libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff8c782000 -     0x7fff8c783ff7  libsystem_sandbox.dylib (220.3) <B739DA63-B675-387A-AD84-412A651143C0> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff8c784000 -     0x7fff8c7d5ff7  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <A4341BBD-A330-3A57-8891-E9C1A286A72D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff8c7d6000 -     0x7fff8c8b0fff  com.apple.backup.framework (1.4.3 - 1.4.3) <6B65C44C-7777-3331-AD9D-438D10AAC777> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff8c92c000 -     0x7fff8ca2efff  libJP2.dylib (850) <2E43216C-3A5A-3693-820C-38B360698FA0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff8ca2f000 -     0x7fff8ca37ff7  libsystem_dnssd.dylib (379.38.1) <BDCB8566-0189-34C0-9634-35ABD3EFE25B> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff8ca38000 -     0x7fff8ca5aff7  libxpc.dylib (140.43) <70BC645B-6952-3264-930C-C835010CCEF9> /usr/lib/system/libxpc.dylib
        0x7fff8ca5b000 -     0x7fff8ca5cfff  liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
        0x7fff8cc52000 -     0x7fff8cc65ff7  libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
        0x7fff8cc66000 -     0x7fff8cd7e92f  libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
        0x7fff8cd7f000 -     0x7fff8cd81fff  libquarantine.dylib (52.1) <143B726E-DF47-37A8-90AA-F059CFD1A2E4> /usr/lib/system/libquarantine.dylib
        0x7fff8cd82000 -     0x7fff8ce20ff7  com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff8ce21000 -     0x7fff8ce3eff7  com.apple.openscripting (1.3.6 - 148.3) <C008F56A-1E01-3D4C-A9AF-97799D0FAE69> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff8ce5a000 -     0x7fff8ce65fff  libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
        0x7fff8ce66000 -     0x7fff8ce9afff  com.apple.securityinterface (6.0 - 55024.4) <614C9B8E-2056-3A41-9A01-DAF74C97CC43> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
        0x7fff8ce9b000 -     0x7fff8cea2fff  libGFXShared.dylib (8.9.2) <398F8D57-EC82-3E13-AC8E-470BE19237D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff8cec6000 -     0x7fff8cecaff7  com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff8ceda000 -     0x7fff8cefbfff  com.apple.Ubiquity (1.2 - 243.15) <C9A7EE77-B637-3676-B667-C0843BBB0409> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
        0x7fff8cefe000 -     0x7fff8d1cfff7  com.apple.security (7.0 - 55179.13) <F428E306-C407-3B55-BA82-E58755E8A76F> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff8d1d0000 -     0x7fff8d1ddfff  com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff8d1de000 -     0x7fff8d1defff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8-DF81-38DD-ACAF-7076B2A26225> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8d1df000 -     0x7fff8d1ebfff  com.apple.CrashReporterSupport (10.8.3 - 418) <DE6AFE16-D97E-399D-82ED-3522C773C36E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff8d1ec000 -     0x7fff8d1f1fff  libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
        0x7fff8d275000 -     0x7fff8d275fff  com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff8d2c1000 -     0x7fff8d2edfff  com.apple.framework.Apple80211 (8.4 - 840.22.1) <7CFDDBBB-87DF-3CB5-AB69-A77D73F26239> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff8d2ee000 -     0x7fff8d2efff7  libremovefile.dylib (23.2) <6763BC8E-18B8-3AD9-8FFA-B43713A7264F> /usr/lib/system/libremovefile.dylib
        0x7fff8d2f0000 -     0x7fff8d2f0fff  com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A-A874-5E18001C8503> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8d4de000 -     0x7fff8d4e0fff  com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff8d4e1000 -     0x7fff8d5ecfff  libFontParser.dylib (84.6) <96C42E49-79A6-3475-B5E4-6A782599A6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff8d792000 -     0x7fff8d795ff7  libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
        0x7fff8d796000 -     0x7fff8d7f0ff7  com.apple.opencl (2.2.19 - 2.2.19) <3C7DFB2C-B3F9-3447-A1FC-EAAA42181A6E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff8d7f1000 -     0x7fff8d8effff  com.apple.QuickLookUIFramework (4.0 - 555.5) <EE02B332-20F3-3226-A022-D71B808E1CC4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
        0x7fff8d9d1000 -     0x7fff8d9deff7  com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff8d9e2000 -     0x7fff8daaeff7  libsystem_c.dylib (825.26) <4C9EB006-FE1F-3F8F-8074-DFD94CF2CE7B> /usr/lib/system/libsystem_c.dylib
        0x7fff8daaf000 -     0x7fff8daceff7  libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
        0x7fff8dacf000 -     0x7fff8dc2dfef  com.apple.MediaControlSender (1.7 - 170.20) <853BE89D-49B0-3922-9ED5-DDBDE9A97356> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
        0x7fff8dc7e000 -     0x7fff8df19ff7  com.apple.JavaScriptCore (8536 - 8536.30) <FE3C5ADD-43D3-33C9-9150-8DCEFDA218E2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
        0x7fff8e0df000 -     0x7fff8e185ff7  com.apple.CoreServices.OSServices (557.6 - 557.6) <1BDB5456-0CE9-301C-99C1-8EFD0D2BFCCD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff8e3c4000 -     0x7fff8e7bbfff  libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff8e7bc000 -     0x7fff8e9a6ff7  com.apple.CoreFoundation (6.8 - 744.19) <0F7403CA-2CB8-3D0A-992B-679701DF27CA> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff8ea35000 -     0x7fff8eba6ff7  com.apple.QTKit (7.7.1 - 2599.31) <1CBAB8B9-E335-33E3-B442-60105D265CB7> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff8eba7000 -     0x7fff8eba8ff7  libdnsinfo.dylib (453.19) <14202FFB-C3CA-3FCC-94B0-14611BF8692D> /usr/lib/system/libdnsinfo.dylib
        0x7fff8eba9000 -     0x7fff8ee4dff7  com.apple.CoreImage (8.4.0 - 1.0.1) <CC6DD22B-FFC6-310B-BE13-2397A02C79EF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff8ee77000 -     0x7fff8eea3fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <B8DE45D7-1827-3379-A478-1A574A1D11D9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
        0x7fff8eea4000 -     0x7fff8ef3ffff  com.apple.CoreSymbolication (3.0 - 117) <C304FDB8-2FF7-34BC-858A-2B96C2B039D5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff8ef40000 -     0x7fff8ef4eff7  libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
        0x7fff8f457000 -     0x7fff8f465ff7  libkxld.dylib (2050.24.15) <A619A9AC-09AF-3FF3-95BF-F07CC530EC31> /usr/lib/system/libkxld.dylib
        0x7fff8f466000 -     0x7fff8f4a6ff7  com.apple.MediaKit (14 - 687) <8AAA8CC3-3ACD-34A5-9E57-9B24AD8AFD4D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff8f4a7000 -     0x7fff8f4abfff  com.apple.IOSurface (86.0.4 - 86.0.4) <26F01CD4-B76B-37A3-989D-66E8140542B3> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff8f4ac000 -     0x7fff8f7c3ff7  com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <1E567A52-677F-3168-979F-5FBB0818D52B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff8f7d2000 -     0x7fff8f7f1ff7  com.apple.ChunkingLibrary (2.0 - 133.3) <8BEC9AFB-DCAA-37E8-A5AB-24422B234ECF> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff8f832000 -     0x7fff8f86ffef  libGLImage.dylib (8.9.2) <C38649ED-E1C9-315E-9953-F33E8C6A3C89> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff8f870000 -     0x7fff8f886fff  com.apple.MultitouchSupport.framework (235.29 - 235.29) <617EC8F1-BCE7-3553-86DD-F857866E1257> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff8f893000 -     0x7fff8f9adfff  com.apple.coreavchd (5.6.0 - 5600.4.16) <0CF2ABE5-B088-3B5D-9C04-47AE708ADAE3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff8f9ae000 -     0x7fff8fa81ff7  com.apple.DiscRecording (7.0 - 7000.2.4) <49FD2D2F-4F2C-39B6-877B-6E3172577D18> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff8fa82000 -     0x7fff8fd39ff7  com.apple.MediaToolbox (1.0 - 926.104) <916B1ACC-2623-39FB-9B5A-1B0162F8C468> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff8fd3f000 -     0x7fff8fd96ff7  com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
        0x7fff8fd97000 -     0x7fff8fdeeff7  com.apple.AppleVAFramework (5.0.19 - 5.0.19) <541A7DBE-F8E4-3023-A3C0-8D5A2A550CFB> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff8fdef000 -     0x7fff8fe04fff  com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff8fe05000 -     0x7fff8fe3dfff  libtidy.A.dylib (15.10) <9009156B-84F5-3781-BFCB-B409B538CD18> /usr/lib/libtidy.A.dylib
        0x7fff8fe41000 -     0x7fff8fe4efff  libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
        0x7fff8fe54000 -     0x7fff8fe7ffff  libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
        0x7fff8fe80000 -     0x7fff8fec3ff7  com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff8fec4000 -     0x7fff908544af  com.apple.CoreGraphics (1.600.0 - 332) <5AB32E51-9154-3733-B83B-A9A748652847> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff9085e000 -     0x7fff908e0ff7  com.apple.Heimdal (3.0 - 2.0) <C94B0C6C-1320-35A1-8143-FE252E7B2A08> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff908e1000 -     0x7fff90a56ff7  com.apple.CFNetwork (596.4.3 - 596.4.3) <A57B3308-2F08-3EC3-B4AC-39A3D9F0B9F7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 50
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 8123
        thread_create: 1
        thread_set_state: 30
    VM Region Summary:
    ReadOnly portion of Libraries: Total=212.3M resident=124.5M(59%) swapped_out_or_unallocated=87.7M(41%)
    Writable regions: Total=134.7M written=21.7M(16%) resident=42.9M(32%) swapped_out=5428K(4%) unallocated=91.8M(68%)
    REGION TYPE                      VIRTUAL
    CG backing stores                  6744K
    CG image                            380K
    CG shared images                    256K
    CoreImage                             8K
    CoreServices                       2928K
    MALLOC                             94.5M
    MALLOC guard page                    48K
    Memory tag=240                        4K
    Memory tag=242                       12K
    Memory tag=243                        8K
    Memory tag=251                       36K
    OpenCL                               52K
    STACK GUARD                        56.1M
    Stack                              15.7M
    VM_ALLOCATE                        16.5M
    __DATA                             17.7M
    __IMAGE                             528K
    __LINKEDIT                         54.6M
    __TEXT                            157.7M
    __UNICODE                           544K
    mapped file                        58.0M
    shared memory                      43.4M
    TOTAL                             525.5M
    Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.5 GHz, 8 GB, SMC 1.69f4
    Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 512 MB
    Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 1024 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334448302D4348392020
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334448302D4348392020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.17)
    Bluetooth: Version 4.1.4f2 12041, 2 service, 11 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: APPLE SSD TS512C, 500.28 GB
    Serial ATA Device: MATSHITADVD-R   UJ-8A8
    USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 3
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
    USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 7
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 4
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
    edited 2013-08-21 20:54
    The main issue I had seems to only occur if a folder was left-over for some reason from another operation.
    I've added some guard code that should keep the problem from recurring. Meanwhile, I'll keep eating dog-food.
    dgately wrote: »
    Jazzed,
    Steps:
    Indeed. Jeff had found a similar issue, and that's what got me started on this .....
    https://code.google.com/p/propside/issues/detail?id=178
    I've been looking at flattenDstProject ... and surrounding code for a while tonight.
    Thanks Dennis!
    tdlivings wrote: »
    Steve
    OS said no way.
    Windows 7 Pro.
    Tom
    Great story Tom. I'll look around for similar anomalies.
  • Ding-BattyDing-Batty Posts: 305
    For those folks on Windows, the Handle utility (from the SysInternal folks, found at http://technet.microsoft.com/en-us/sysinternals/bb896655) can tell what files and directories are opened by which processes. I have used it in the past and it helped solve some "unable to delete/move" problems.
