GyroScope Problem
kenwtn
I just plugged in Parallax's Gyroscope module and ran test program. When displaying X,Y,Z I get -1 for all 3 values? The Connection is very straight forward so really not sure what is going on with it unless the Module itself might be bad. Note: just took it out of pack today for the 1st time.
On the PDF download from Parallax it shows Connecting Gnd, Vdd, SCL, SDA But further reading shows CS 1: For IC2 0: For IC2 Disabled I currently do not have this pin connected.
Also, I using a BS2Pe
Below is my CODE:
' {$STAMP BS2pe}
' {$PBASIC 2.5}
BaudMode CON 84 '2400 True
LCD PIN 15 'LCD Display
SDA PIN 0 ' SDA of gyro connected to P0
SCL PIN 1 ' SCL of gyro connected to P1
WRITE_Data CON $3C ' Requests Write operation
READ_Data CON $3D ' Requests Read operation
MODE CON $02 ' Mode setting register
X_MSB CON $03 ' X MSB data output register
X VAR Word
Y VAR Word
Z VAR Word
rawl VAR Word
rawh VAR Word
' Variables for I2C communications
I2C_DATA VAR Byte
I2C_LSB VAR Bit
I2C_REG VAR Byte
I2C_VAL VAR Byte
HIGH LCD ' Set Display Line to Low
PAUSE 100 ' Power up delay
SEROUT LCD, BaudMode, ["?S0"] ' No Boot Screen
PAUSE 200 ' pause to allow LCD EEPROM to program
SEROUT LCD, BaudMode, ["?G420"] ' Sets geometry of LCD as 4X20
'SEROUT LCD, 84, ["?BFF"] '100% backlight
SEROUT LCD, Baudmode, ["?B7F"] '15% backlight
'SEROUT LCD, Baudmode, ["?B7E"] '50% baclight
PAUSE 300 ' pause to allow LCD EEPROM to program \
SEROUT LCD, BaudMode, ["?c0"] 'Kill Cursor
GOSUB ClearScreen
I2C_REG = MODE ' Set operating mode to continuous
I2C_VAL = $0
GOSUB I2C_Write_Reg
PAUSE 1000
DO
GOSUB GetRawReading
SEROUT LCD, BaudMode, ["?y0?x04"]
SEROUT LCD, BaudMode, ["RAW X = ",11, SDEC X]
SEROUT LCD, BaudMode, ["?y1?x04"]
SEROUT LCD, BaudMode, ["RAW Y = ",11, SDEC Y]
SEROUT LCD, BaudMode, ["?y2?x04"]
SEROUT LCD, BaudMode, ["RAW Z = ",11, SDEC Z]
PAUSE 250
LOOP
ClearScreen:
SEROUT LCD, Baudmode, ["?f"] ' clear the LCD
SEROUT LCD, BaudMode, ["?y0?x00"] ' cursor at line 0, col 0
PAUSE 500
RETURN
GetRawReading:
PAUSE 400 ' Wait for new data
' Send request to X MSB register
GOSUB I2C_Start
I2C_DATA = WRITE_Data
GOSUB I2C_Write
I2C_DATA = X_MSB
GOSUB I2C_Write
GOSUB I2C_Stop
'Get data from register (6 bytes total, 2 bytes per axis)
GOSUB I2C_Start
I2C_DATA = READ_Data
GOSUB I2C_Write
' Get X
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_ACK
X = (rawH << 8) | rawL
' Get Z
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_ACK
Z = (rawH << 8) | rawL
' Get Y
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_NACK
Y = (rawH << 8) | rawL
GOSUB I2C_Stop
RETURN
I2C functions
' Set I2C_REG & I2C_VAL before calling this
I2C_Write_Reg:
GOSUB I2C_Start
I2C_DATA = WRITE_DATA
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
I2C_DATA = I2C_VAL
GOSUB I2C_Write
GOSUB I2C_Stop
RETURN
' Set I2C_REG before calling this, I2C_DATA will have result
I2C_Read_Reg:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
GOSUB I2C_Stop
GOSUB I2C_Start
I2C_DATA = READ_DATA
GOSUB I2C_Write
GOSUB I2C_Read
GOSUB I2C_NACK
GOSUB I2C_Stop
RETURN
I2C_Start:
LOW SDA
LOW SCL
RETURN
I2C_Stop:
LOW SDA
INPUT SCL
INPUT SDA
RETURN
I2C_ACK:
LOW SDA
INPUT SCL
LOW SCL
INPUT SDA
RETURN
I2C_NACK:
INPUT SDA
INPUT SCL
LOW SCL
RETURN
I2C_Read:
SHIFTIN SDA, SCL, MSBPRE, [I2C_DATA]
RETURN
I2C_Write:
I2C_LSB = I2C_DATA.BIT0
I2C_DATA = I2C_DATA / 2
SHIFTOUT SDA, SCL, MSBFIRST, [I2C_DATA\7]
IF I2C_LSB THEN INPUT SDA ELSE LOW SDA
INPUT SCL
LOW SCL
INPUT SDA
INPUT SCL
LOW SCL
RETURN
Below is my CODE:
' {$STAMP BS2pe}
' {$PBASIC 2.5}
X VAR Word
Y VAR Word
Z VAR Word
rawl VAR Word
rawh VAR Word
I2C_DATA VAR Byte
I2C_LSB VAR Bit
I2C_REG VAR Byte
I2C_VAL VAR Byte
GOSUB ClearScreen
I2C_VAL = $0
GOSUB I2C_Write_Reg
PAUSE 1000
DO
GOSUB GetRawReading
PAUSE 250
LOOP
ClearScreen:
PAUSE 500
RETURN
GetRawReading:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = X_MSB
GOSUB I2C_Write
GOSUB I2C_Stop
GOSUB I2C_Start
GOSUB I2C_Write
' Get X
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_ACK
' Get Z
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_ACK
' Get Y
GOSUB I2C_Read
rawH = I2C_Data
GOSUB I2C_ACK
GOSUB I2C_Read
rawL = I2C_Data
GOSUB I2C_NACK
GOSUB I2C_Stop
RETURN
I2C functions
I2C_Write_Reg:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
I2C_DATA = I2C_VAL
GOSUB I2C_Write
GOSUB I2C_Stop
RETURN
I2C_Read_Reg:
GOSUB I2C_Start
GOSUB I2C_Write
I2C_DATA = I2C_REG
GOSUB I2C_Write
GOSUB I2C_Stop
GOSUB I2C_Start
GOSUB I2C_Write
GOSUB I2C_Read
GOSUB I2C_NACK
GOSUB I2C_Stop
RETURN
I2C_Start:
LOW SDA
LOW SCL
RETURN
I2C_Stop:
LOW SDA
INPUT SCL
INPUT SDA
RETURN
I2C_ACK:
LOW SDA
INPUT SCL
LOW SCL
INPUT SDA
RETURN
I2C_NACK:
INPUT SDA
INPUT SCL
LOW SCL
RETURN
I2C_Read:
RETURN
I2C_Write:
INPUT SCL
LOW SCL
INPUT SDA
INPUT SCL
LOW SCL
RETURN
You're right about the connection looking pretty straight forward. Just the four pins as shown on page 2 of the guide are required.
I think receiving all "-1" values indicate a communication problem. Sometimes the connection in a breadboard can be bad. I'd suggest pulling the wires and sensor out of the breadboard and plug it back in in a different location. Use a different set of hookup wires too.
I've had a couple of circuits not work until they were moved and rewired. I don't know if connection problem was the wire's fault or a bad clip inside the breadboard's fault.
