Prop question — Parallax Forums
Prop question
CenlasoftCenlasoft Posts: 265
edited 2013-08-19 08:31 in Propeller 1
Hello,
I had a PropBOE, but it failed twice and I had to send it back twice. My question is: Can I use the spin code from "Learn" with a prop professional board. I know it does not have all the feature, but I would think I could use some of the code.
Curtis
  • ElectrodudeElectrodude Posts: 1,687
    Yes, you can. They both have propellers. If you wire up the PPDB the same as the parts of the PropBOE that you're using (you don't have to wire up the unused parts), then it should work fine.
