6.25mhz crystal oscillator — Parallax Forums
FrannyFranny Posts: 127
edited 2013-08-18 17:30 in Propeller 1
What's the purpose of having the ability of swapping crystals?
    edited 2013-08-17 14:40
    So you can run at 100MHz giving you 10ns timing resolution and 25MIPS per cog
  • FrannyFranny Posts: 127
    edited 2013-08-17 14:44
    But what's the point? How is it different from the 5mhz?
    edited 2013-08-17 14:48
    Running the Propeller at 100 mHz instead of 80. So you get more cpu cycles. It's basically over clocking.
    edited 2013-08-17 14:55
    Oh, I see, So what's the catch when you overclock it, Can it crash?
  • jmgjmg Posts: 15,200
    edited 2013-08-17 17:25
    Franny wrote: »
    You have less margin, but remember the 80Mhz is at high temperature and low voltage.
    Many vendors specify more than one Frequency, and the Prop probably should do that too.
    Currently they have a single spec of this
    ie -55°C < Ta < +125°C, >2.7V => Up to 80MHz,
    They could probably add something like
    ie -40°C < Ta < +85°C, >3.0V => Up to 100MHz
    edited 2013-08-18 07:36
    Thanks for the help.
    edited 2013-08-18 08:45
    The Parallax Laser Range Finder uses a 6MHz crystal and runs at 96MHz. Apparently the extra speed was required to interface with the camera used on the LRF.
    As you've probably noticed, a lot of Propeller boards use a socketed crystal. I'm sure there are special sockets for this purpose but you can also use these machine headers as crystal sockets.
  • blittledblittled Posts: 695
    edited 2013-08-18 12:27
    The PropScope uses a 6.25MHz crystal so it can do 100MHz A/D sampling
    I regularly overclock the prop to 104MHz using a 6.5MHz xtal. But be warned, overclocking also requires special layout and use of decoupling capacitors. There are a number of threads that address these issues.
