Found some cool probes on eBay...
http://www.ebay.co.uk/itm/290913574716?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Springloaded and very, very sharp tips...
Not a clue as to what they're really used for, but I figure that with an even one hundred of them, I'll find something they can be used for.
If I built a mini hexapod robot with these as the tip of the legs, though, it would probably be capable of climbing vertical walls...
(Would need a bunch of very small micro servos or other motors, though. Need to check eBay again... )
Should have guessed.
Edit:
and now I found 1.5Gram linear servos...
http://www.ebay.co.uk/itm/1-5-Gram-RC-servo-1-5g-For-Ultra-Micro-3D-Aircraft-BR403-/360548726089?pt=AU_Toys_Hobbies_Radio_Controlled_Vehicles&hash=item53f260f549
Those are just so cool that I got to get me some... Or more than some...
3.7gram rotary servos are cheaper and not all that much bigger, but... DANG! 1.5 GRAMS!
I found this on EBay last night. I did some checking and seen what they are worth so I bought it. Now today the seller wants to cancel the transaction because "The Item is Out Of Stock" WHAT THE BLEEP??? How is a USED item out of stock. I refused to cancel the transaction. I am pretty sure what happened is that the Buy It Now price was suppose to be $99.99 and someone messed up so the seller thought he would just cancel the transaction. Had the item been new and then I was told it was out of stock I would have been OK with it. But how is a USED item that you took a picture of suddenly out of stock. Now he says he will find one on EBay, buy it and send it to me. I bet it is the same one that is in the pic!!!!!
Is it safe?
(Yes, I already have them... that's why I know they're so sharp... Ouch!)
Ordered a couple of the 1.5gram servos. They're too cool not to have...
May add a few 3.7grams, too.
How many servos can a single Propeller handle?
(Probably needs some driver or buffer circuits, too)
