Object start timeout
I'm wondering if it's possible to start an object as part of the main program and somehow set a timeout limit so if it does not start properly have it reboot and start over.
I have a display that sometimes comes up with some gibberish and doesn't return the value from it's start up method so the program hangs. If I had a way of doing a timeout so that if the result isn't received in say 1 second that it reboots.
Anyone have any ideas they'd like to share on how this could be done?
So if rslt isn't returned in 1 second it would reboot and try again.
PUB Main | rslt repeat rslt := \display.start if rslt == -1 quit else rebootPUB Main | rslt, t t := cnt repeat until (cnt - t) / (clkfreq / 1000) > 1000 OR rslt == -1 rslt := \display.startI'm not sure I follow what you're saying here... do I need to launch a timer object in it's own cog? Just to clarify- when the display does start up ok (-1) the program continues and runs.
If the Start method doesn't always return a value then another cog would need to monitor it.
If you already have another cog running Spin code, you could use it to do the monitoring but if don't have another cog running Spin code, then launching a timer cog should work.
PUB Main globalDisplayReturn := -2 ' some impossible return value watchdogCog := newcog(Watchdog(1000), @stack) 'watchdogCog would need to be global as it is used in this program globalDisplayReturn := \display.start ' do the rest of your program PUB Watchdog(watchInterval) | timer watchInterval *= clkfreq / 1000 timer := cnt repeat while (cnt - timer) < watchInterval and globalDisplayReturn == -2 if globalDisplayReturn == -2 reboot else cogstop(watchdogCog) 'cogstop(cogid) ' I think this is another option for a cog to stop itself.I have not tested the above code, but I think something like that should work.
It sounds like the main program freezes if the display driver doesn't launch properly. If this is the case the main program can't check anything.
The code in post #9 assumes if the display driver returns any value, then the program isn't frozen and there's not a need to reboot.
Is there a return value which would indicate there's a problem? If so you'd want to add a check for this after the display is started.
That looks like something that may work. Shop is shut down for tonight but will check it out in the morning.
I think it could be even simpler:
This way if the display starts then fine otherwise it should invoke the WatchDog and reboot.
It make recover after a non-start of the display part (what;s that all about anyway??)
But it doesn't provide a way to know that the display.start failed.
And the next thing you do is stop it, so whay bother starting it in the first place??
See Duane's (#10)
The code in post #12 is just about the same as the code in post #9. I originally had the same code Don posted but then remembered he had an abort trap and a return value. I figured he would want the return value if the object aborted. I figured an abort was different than a freeze.
The code stops the watchdog cog after the Start call since if the Start method doesn't freeze, the watchdog is no longer need. I gather the only information to be gain from adding a return value is that the driver was successfully started. The return value doesn't exist when there is a problem.
PUB Main | WatchDogCog WatchDogCog := cognew(WatchDog, @stack) ' Launch WatchDog for display startup display.start ' Start display cogstop(WatchDogCog) ' If display started ok then stop WatchDog PUB WatchDog | t t := cnt - 1776 ' sync with system counter repeat 750 ' Set delay for 750 mS waitcnt(t += MS_001) rebootThanks Duane for your help!
What I'm using is a NewHaven Display 20x4 OLED in 4 bit parallel mode. I had to modify the OBEX 4 bit LCD driver to work with this display. I consulted with NewHaven as to their requirements for initializing the display. That part I got fixed.
So my main program runs through a repeat loop reading a rotary encoder to select from different menu options. It repeats the "moveto (line, col)" and then displays a message at that line. The problem that I am having is that if you download new code to the Prop or happen to reset the Prop via USB then I would intermittantly get a screen full of gibberish and the program locked up because it couldn't get past the initialization of the OLED display. So basically when the display has already been running and you do a warm reset / restart.
What I discovered today thanks to the WatchDog code (thanks Duane!) is what causes the problem. It has to do with the continual commands being sent to the display in the repeat loop and if the Prop happens to be reset in the middle of one of those commands then the display gets "lost" the next time it is initialized from reboot. If you reboot it one more time it straightens out. Always.
So next I need to find out if there is anything else I can do to force the display to re-initialize if it would have happened to be in the middle of a command instruction and was interrupted.
