Fix for Day of Week-Bug in SNTP - W5100/W5200 driver — Parallax Forums
msrobotsmsrobots Posts: 3,709
edited 2013-08-10 14:36 in Propeller 1
It took me a while to figure this out. The day of the week is 2 days off.
So the writeTime method of S35390A_RTCEngine needs 1-7 for Sunday to Saturday.
Inside the clock it is using 0-6 but the writeTime-method subtracts 1 from the day of the week before setting.
The HumanTime method calculates the days since January 1 1900 a Monday.
So to calculate the correct weekday we need to take one day more to calculate the correct modulus starting at Sunday not Monday.
And we need to add 1 to have the correct value from 1-7 instead 0-6.
PUB HumanTime(Offset,TimeStampAddress)|i,Seconds,Days,Years,LYrs,DW,DD,HH,MM,SS,Month,Date,Year
Seconds := long[TimeStampAddress] + Offset * 3600
Days := ((Seconds >>= 7)/675) + 1 '<- Days since Jan 1, 1900 ... divide by 86,400 and add 1
' DW := (Days-1) // 7 ' <--- wrong starting at Monday and giving 0-6
DW := (Days // 7) + 1 ' <--- correct Sunday-Saturday and 1-7
voila!
now the weekday is correct:smile:
Enjoy!
  • Mike GMike G Posts: 2,702
    edited 2013-08-10 05:04
    Ah... thanks again Mike. I'll correct the source.
    I was recently alerted to an issue via email related to the UDP protocol and multiple clients. I've been meaning to jump back into the code base - refactor, add comment, write docs, fix the UDP bug.... On the other hand, I really really want to convert the code base to C. Plus I'd like to move the buffer pointer logic from SPIN to PASM. Lot's of wants and little time.
    I appreciate the feedback Mike and I can tell ya how much I appreciate that you're using the new driver.
    If you don't mind, what are you working on?
    edited 2013-08-10 12:49
    I do not mind at all. A friend of mine in Germany is working on some simple industrial control for a producer of health supplement stuff. Not real medicine, more vitamin and sport related stuff.
    They (an him) are using some microcontrollers called c-control from a German company called Conrad. As far as I was able to find out they are something like basic-stamps. (BASIC++ ...?...anyone?)
    My goal now is to get them to use Propellers instead. So I am sneaking in some spinnerettes to connect those c-controls to the Ethernet (prob. just intranet) and then to some software I will write for them to capture 'live' data out of the production into a database.
    Small step but right direction. The main hindering factor is the language-barrier - none of them is good enough in the English language to read/understand the Propeller documentation.
    That Pharma-Company is something like the German version of a startup and still going strong. So there is room to grow and I am sure they will be better off with the Propeller.
    IMHO the main problem with the spin code is that the prop-tool is not removing unused functions/methods. (For example the SNTP object: 322 longs. reduced to what we use: 152 longs). Thus we are running out of space. I am not at all a fan of C/C++. All those decades of programming for a living I was able to avoid it. Not that I can't program in C, I can and I did - but just for small stuff at home, never at work.
    Working mostly on IBM/370s in Assembler and COBOL for the first decade of programming can mess with your mindset. So I have a hard time with C. Not verbose enough for me. On the other hand I am programming c# since net-framework 1.0 beta so C is not really a hurdle. Its just that most source in c is so ugly to read.
    I do understand Parallax's move to C but I personally prefer Spin/Pasm over C/GAS.
    But on the third hand it might be time to jump that hurdle and embrace C on the propeller, but I am not sure if I want to.
    Because I know myself. I would start to do all the translation work to German and spend all my time with the tools instead of programming for fun.
    Enjoy!
    P.S.
    and there is that open-source project OpenCobol providing C source and runtime to compile COBOL to C...
    There is a lot of wiggle room in the code base depending on what ya need. Let me know if you need any help or suggestions.
