line following with stingray
So I had my line follower (boe bot kit + qti sensors) working perfectly, I decided to get the sting ray chassis and two HB25 motor controllers after modifying the code for the HB25's it just seems out of wack. From what I am thinking, the way the servos was working was that each time you would pulsout it would turn the wheels a few degrees then stop and wait for the next pulsout. The fact that it would stop and go so quickly made it seem very smooth. Now with the DC motors, I think each time it sends the pulsout it seems to start the wheels moving but it doesnt stop after each pulsout like the servo's did it just keeps moving.
The boebot was very accurate in that it would scan then move a little, scan then move a little again. But with the stingray chassis and DC motors, its scanning at the same speed but moving much to fast that it keeps getting ahead of its self. If anyone can help out at all it'd be greatly appreciated!
This is the old code, pretty much it only moved forward when the two middle sensors both detected the line (0110) and any other sensor combination would have the robot adjust untill it was completely centered.
This is the new code, first adjustment i had to make was to force the robot to turn sharper by having both wheels rotate the same direction so it would pivot other wise the turn radius was much to large. the second was to adjust the speed because the power from the dc motors is so strong that it wasnt slowing down fast enough at the corners and it would just shoot off the track.
Also, just thought i should mention the corners i'm having trouble with are 90 degree turns.
' {$STAMP BS2} ' {$PBASIC 2.5} qtis VAR Nib OUTB = 11 DO GOSUB Check_Qtis SELECT qtis CASE 00 PULSOUT 12, 750 PULSOUT 13, 650 CASE 00 PULSOUT 12, 750 PULSOUT 13, 650 CASE 00 PULSOUT 12, 750 PULSOUT 13, 650 CASE 10 PULSOUT 12, 750 PULSOUT 13, 650 CASE 10 PULSOUT 12, 850 PULSOUT 13, 650 CASE 10 PULSOUT 12, 850 PULSOUT 13, 750 CASE 11 PULSOUT 12, 850 PULSOUT 13, 750 CASE 01 PULSOUT 12, 850 PULSOUT 13, 750 CASE 11 PULSOUT 12, 850 PULSOUT 13, 750 CASE ELSE ENDSELECT LOOP Check_Qtis: DIRB = 11 PAUSE 0 DIRB = 00 PAUSE 0 qtis = INB RETURN
' {$STAMP BS2} ' {$PBASIC 2.5} HB25 PIN 15 qtis VAR Nib OUTB = 11 DO : LOOP UNTIL HB25 = 1 LOW HB25 PAUSE 5 PULSOUT HB25, 750 PAUSE 1 PULSOUT HB25, 750 DO GOSUB Check_Qtis SELECT qtis CASE 00 PAUSE 5 PULSOUT HB25, 700 PAUSE 1 PULSOUT HB25, 700 CASE 00 PAUSE 5 PULSOUT HB25, 700 PAUSE 1 PULSOUT HB25, 700 CASE 10 PAUSE 5 PULSOUT HB25, 700 PAUSE 1 PULSOUT HB25, 700 CASE 00 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 700 CASE 10 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 700 CASE 10 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 700 CASE 01 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 800 CASE 11 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 800 CASE 11 PAUSE 5 PULSOUT HB25, 800 PAUSE 1 PULSOUT HB25, 800 CASE ELSE ENDSELECT LOOP Check_Qtis: DIRB = 11 PAUSE 0 DIRB = 00 PAUSE 0 qtis = INB RETURN
Edit: Some how a portion of my post was deleted!!!! What I meant to ask was have you checked your HB-25's for a dead stop at 750? I have in the past noticed that a couple of mine are off a bit like an uncentered servo.
1) Switch to lower gear motors for faster control response and more braking
2) Slow way down on your PWM and/or lower your motor voltage to reduce overcontrol
3) Adjust the location of your sensors front & back and spacing for better response
Per #3, take a tip from the FAST line follower robots. Instead of 2 or 3 sensors, have an array of 8 or 10 sensors so you can react faster when the line moves/curves. Of course there's more processing involved to use more sensors.
http://forums.parallax.com/showthread.php/131242-Parallax-Stringray-Robot-1st-Place-at-Carnegie-Mellon-University-Mobot-Race-2011?highlight=Stingray
1. where can i buy motors other than online, hobby stores? im also in the LA area
2. I have been playing with the slower speeds, my goal isnt to have a fast robot but even with slower speeds the braking is still a problem =/
3. what type of sensor position would make for better response?
