fsrw 'opendir' ? — Parallax Forums
fsrw 'opendir' ?
RsadeikaRsadeika Posts: 3,902
edited 2013-07-31 12:37 in Propeller 1
The problem, at least it is not as expected, is occurring in PUB xbeeTerm, specifically how 'dir' is being shown on the terminal screen. I have the same code for 'dir' in PUB Main, and that seems to be working as expected. In the xbeeTerm, when I run 'dir', the directory listing is all on one line, even though I have a CR implemented to show the directory listing is on its own line. This must be another one of my rookie mistakes that I cannot figure out.
Any ideas for code reduction as it concerns the menu items in the DAT section? It seems that I have to duplicate the items so each item is going to the correct terminal screen.
Ray
'' PboeBase.spin
'' July 28, 2013
CON
  _clkmode   = xtal1 + pll16x
  _xinfreq   = 5_000_000
OBJ
  term  : "Extended_FDSerial" '' An enhanced version of (FDS)
  xbee  : "Extended_FDSerial"  ''
  misc  : "tools"             '' My object that contains some common tools.
  sdfat : "sd_api"
  tusd  : "fsrw"
VAR
  long xbeeStack[60]  '' Most of the time 10 would suffice.
  byte tbuf[20]
  long mounted
PUB Start
  Cogxbee := cognew(xbeeTerm, @xbeeStack)
  misc.waitMS(250)
  term.Start(31,30,0,115200)
  misc.waitMS(250)
  term.str(string("Mounting uSD card.",13,10))
  if (sdfat.mount_sd == false)
    term.str(string("SD not mounted",13,10))
    mounted := false
  else
    term.str(string("SD Mounted.",13,10))
    mounted := true
  Main
'' To be used as local access for maintenance??
PUB Main | inSbyte, inAbyte
    repeat
      inSbyte := term.Rx
      if inSbyte == 13
        term.str(string("This is the BASE unit.",13,10))
        repeat
          term.Tx("#")
          term.RxStr(@TinStrg)
          if strcomp(@TinStrg, @stopProg)
            term.str(@TinStrg)
            CRLF
            term.str(string("Program Stopped!",13,10))
            cogstop(Cogxbee)
            abort
          elseif strcomp(@TinStrg, @Tmenu)
            term.str(@TinStrg)
            CRLF
            TmainMenu
          elseif strcomp(@TinStrg, @Tmount)
            term.str(@TinStrg)
            CRLF
            if (mounted == false)
              sdfat.mount_sd
              mounted := true
            else
              term.str(string("SD already mounted.",13,10))
          elseif strcomp(@TinStrg, @Tumount)
            term.str(@TinStrg)
            CRLF
            sdfat.unmount_sd
            mounted := false
            term.str(string("SD unmounted.",13,10))
          elseif strcomp(@TinStrg, @Tdir)
            term.str(@Tinstrg)
            CRLF
            else
              tusd.opendir
              repeat while 0 == tusd.nextfile(@tbuf)
                term.str(@tbuf)
                CRLF
              term.str(string("That's the dir",13,10))
          else
            term.str(string("Invalid Command!",13,10))
'' To be used as actual program usage.
PUB xbeeTerm | inSbyte, inAbyte
''           Rx Tx Mode BAUD
  xbee.Start(15,14,0,9600)
  repeat
    inSbyte := xbee.Rx
    if inSbyte == 13
      xbee.str(string("This is the air BASE unit.",13,10))
    repeat
      xbee.Tx(">")
      xbee.RxStr(@XinStrg)
      if strcomp(@XinStrg, @XonLED) '' For program testing
        misc.high(26)
        'CRLF
      elseif strcomp(@XinStrg, @XoffLED) '' For program testing
        misc.low(26)
        'CRLF
      elseif strcomp(@XinStrg, @Xmenu)
        'CRLF
        XmainMenu
      elseif strcomp(@XinStrg, @Xdir)
          xbee.str(string("SD not mounted",13,10))
        else
          tusd.opendir
             xbee.str(@tbuf)
             xbee.Tx(10)
             xbee.Tx(13)
          xbee.str(string(13,10,"That's the dir",13,10))
      else
        xbee.str(string("Invalid Command!",13,10))
PUB TmainMenu
  term.str(string("Menu: menu - this menu, Quit - end program",13,10))
  term.str(string("      dir - SD directory, mount - uSD, unmount - uSD",13,10))
PUB XmainMenu
  xbee.str(string("Menu: menu - this menu, dir - SD directory ",13,10))
  xbee.str(string("      onLED, offLED ",13,10))
PUB CRLF
  term.Tx(13)  '' CR
  term.Tx(10)  '' LF
DAT
XinStrg byte "               ",0
XonLED byte "onLED",0
XoffLED byte "offLED",0
Xmenu byte "menu",0
Xdir byte "dir",0
TinStrg byte "               ",0
TonLED byte "onLED",0
ToffLED byte "offLED",0
Tmenu byte "menu",0
Tdir byte "dir",0
Tmount byte "mount",0
Tumount byte "unmount",0
stopProg byte "Quit",0
Cogxbee byte  '' Capture ID of started Cog.
    edited 2013-07-31 09:09
    You are sending LF and CR through the xbee, so it should display OK. Is you're Extended_FDSerial object filtering out the LF? Do you have LF disabled on your remote terminal?
  • RsadeikaRsadeika Posts: 3,902
    Thanks Dave for looking at the code. I new it was a rookie mistake, it should be:
              xbee.Tx(13)
              xbee.Tx(10)
    instead of:
              xbee.Tx(10)
              xbee.Tx(13)
    I was scratching my head for hours trying to figure that one out, luckily my program is not a thousand lines of code, yet.
    Ray
