quad dc motor driver
Hi folks,
Has anyone developed a brushed DC motor drive for the prop with at least the following specs:?
1) 4 motors
2) 25-36v range motor voltage
3) 10A - 25A continuous current capability
4) quick start prop header
5) ability to use quickstart Ethernet board
I'm thinking of designing and building one, but I don't want to if someone has already done so. I can buy single and dual motor drivers, like a Pololu or Dimension engineering board, but I cant find any that will handle 4 motors.
1) 4 motors
Those are some pretty high values.
Does the motor need to be bi-directional? or just off and forward?
Is the median 18A peak values for a short time, or continues?
4 of these: DRV8432 (let me know if you want me to design board)
Current in Parallel Mode: 14 A Continuous (24 A Peak)
http://www.mouser.com/ds/2/405/sles242d-127577.pdf
