eeprom data sheet question
Hey all
I'm trying to learn more about the eeprom on the quickstart and i2c in general.
On the datasheet for this eeprom http://ww1.microchip.com/downloads/en/DeviceDoc/21203Q.pdf on page 2, the parameter D7 calls out a pin capacitance of 10 pf and the notes section says Vcc=5.0v TA=25C and Fclk=1MHz.
I'm trying to figure out what the capacitance should be at 3.3 volt and 400 kHz.
Capacitive reactance is 1 / 2 pi f c but it seems like there is more to figuring this out than just just determining the reactance and then rearranging for 400 kHz.
Can you help me out a bit here?
Robert
Robert
I'm waiting on some B82P714 i2c bus extender chips to show up in the mail and would like to experiment with long cables, varying speeds and pullup resistors so wanted to try and see which formula applies (or doesn't!.)
Do you know of any good online calculation sites that allow you to plug in some numbers to get a good approximation of characteristics for a given bus design?
A matching resistor corrects a mismatch at the far end and absorbs some of the reflections caused by the mismatch. If the source and load are well matched in impedance and the cable is matched as well, there is little in the way of reflections and the noise caused by them.
Look at discussions of transmission lines, impedance matching, and reflections.
Robert
