Using MTTTY To Set IP Address
Hi. I have recently dug out a PINK module to use in a project. It does not show up when using ipsetup even when I use a dedicated 5 V voltage regulator. The problem with me using MTTTY is I do not know how to use it and cannot get the nb> prompt to show on the screen. I am using a MAX232 module with GND, VCC, TX, and RX pins.
1. when you plug it into the network, do you get the green leds on the Ethernet connector to light?
2. On ipsetup, have you got the ip addresses set to 0.0.0.0 ? Baud rate at 115000?
3. Once the module is identified, you'll have its local IP address and be able connect using a browser.
4. not familiar with the nb> prompt you speak of. There are a number of simple test programs for the Stamps to check out the operation. If you get the module to connect, I've got several programs for systems I've built around the PINK which might help. Just let me know how you make out.
Cheers,
We had to contact Parallax, that evening as the project presentation was the next morning, and ask for help. They told us how to do so, using a MAX232 line driver to access the PINK serially using MTTTY, if I remember correctly. I was hoping to figure out how to do this this time as it seems like a handy thing to know.
