Has anyone made GPS module (part 28146) Smart Mode work with an Arduino?
The C++ basis seems to be a major problem; I haven't seen anyone posting a success story using Smart Mode to call and receive one piece of information on any forums. I have seen recommendations of putting a diode between the pins and of setting pins high/low or input/output as the loop runs; can anyone confirm a code they have working? I found an alternative way to make my code work for the project I have been working on, but expanding this project will be much easier if I can just use Smart Mode to ask for the relevant data. Thanks!
After reading your message a few times I am not clear if you're having code issues, hardware issues or interface issues. I don't know about Arduino serial port interfacing, but I am guessing it is not possible to do send and receive on a single I/O pin? In this thread you said you had it working. And in this other thread (presumably the original?) I offered a method for connecting RX/TX pins to SIO. You never mention if you even tried it. To be honest there are too many threads on the same subject making it impossible to know what has ben covered. Please keep in the original thread until the issue is marked resolved. Posting new threads only inhibits progress on this issue.
To answer your question, I have gotten various iterations of Parallax's Smart Mode GPS units connected to the Arduino in smart mode. Simple logic steering with the resistor/diode allows you to use two IO pins in half-duplex mode with the GPS. It's the same arrangement used with many other Parallax products that depend on open drain IO pins.
Somewhere a while back I posted code for this, and I can repost if you're interested in seeing another approach.
-- Gordon
