ELEV-8 BEC/ESC connection clarification
Hello, I found an inconsistency in comparing the Hoverfly instructions and the ELEV-8 build instructions. The Hoverfly instructions tell you to cut the power wire for all but one of the ESCs, i.e. the Hoverfly is only getting power from a single ESC and not all 4 (see Figure 9: Typical wiring harness layout). This makes sense that it is only getting power form a single source.
I personally just use a single supply.
