Radio control servo motors don't have the ability to use PID. They have a simple servo mechanism inside that is not adjustable or controllable. The feedback portion of the servo mechanism is even disabled to make what's called a "continuous motion servo" motor.
There are actuators that look much like radio control servos, but use a digital controller and a high speed bus to communicate with the actuators. These have PID controllers and the parameters can be modified.
B.C.Wang, this may or may not be what you need for your present application but the following link has an excellent tutorial about P.I.D and is well worth reading any time.
What are you trying to do?
Mike Green,I use Hs322hd servos on my quad crawler...
If this,what I can do to let it respond fast?
(the ramp rate I use the fastest,the baud rate is also)
You need some sort of feedback to use PID. Normal hobby servos don't provide feedback. It's possible to add an encoder to obtain feedback but that requires an additional sensor.
What does the servo do in your quad crawler? Has it been modified to be continuous rotation?
What devices are communicating at this baud? This doesn't make much sense in terms of a normal hobby servo.
1
What it do is to keep my quad crawler's body balance when I tilt the board.(my quad crawler is on a board)
Besides,I think it might be continuous rotation...
2
I think my device also have sensor "H48C 3-axis accelerometer",so can it make a feedback?
3
bs2p24,after I improve the baud rate,it seems to respond quickly...
http://forums.parallax.com/showthread.php/77656-PID-Control-Intro-with-the-BASIC-Stamp?highlight=proportional
Jeff T.
1
2
3
