xbee pcb antenna - can I add an external antenna?
Electrodude
Can I solder an external antenna connected by a coaxial cable onto a XBee 1mW PCB antenna module? The XBee won't be mounted in a metal case but there will be enough metal around it to make an external antenna necessary. The XBee seems to have a pad to solder an antenna or coaxial cable to on the top, but the whole top of the board seems to be the antenna and my uncle, who's an RF expert and gave me the antennas, said the on-board antenna would have to be disconnected before I could put my own antenna on or it wouldn't work well and it looks like it would be impossible to remove this antenna. I couldn't find any documentation on if I can and if so how to connect to those pads. Does anyone know?
Electrodude
Electrodude
Sorry I didn't know they had those and I was thinking of the chip antennas.
The antenna in this case is part of the PCB. It curves around the top edge of the XBee.
I suppose one could cut the trace where the antenna meets the rest of the board but I think using a different XBee would be better alternative to hacking up one with a PCB antenna.
@Duane Degn: It looks like the curvy trace on the top, which I assumed was the antenna, is connected to ground... Yes, getting the right one would definitely be a better idea, but this has to be done by tonight. Also, Parallax doesn't have the coaxial cable version.
EDIT: Yes Parallax does have the coax version. I got the Parallax XBee pack Radioshack had (on sale too!) so I didn't have a choice.
EDIT2: But Parallax's coax XBee is 900Mhz and not 2.4Ghz
Can you test the unmodified version to see if it will work well enough?
I'll let others offer suggestions about how to modify the XBee. I don't know enough to give good advice on this topic.
Wow! That is so cool!
That's a great looking car.
Do you have an extra XBee you could sacrifice for testing? If so, you could try adding a wire antenna and see if the range improves.
I take it you couldn't find the more powerful versions of XBees at RS?
I'm looking forward to reading about the race. Good luck.
